Trojan ??
Trojan ??
- DOUGNASH
OK lets talk about this one.
I might be wrong but this thing is a total custom boat.
Somebody put some big money into this vessel.
I think it started out as a 10 meter.
It looks like they put the motors in the lower cockpit.
Arneson surface drives!!!! that is crazy, major investment here. I found an old quote from 10 years ago to convert my inboards to surfaces drives, it was like a 60k investment, they wanted around 15k for EACH 5 blade prop!
did they extend the length of the boat?
Its really hard to tell what is going on from the pics..
too bad there are no more photos.
This is definately a stretched 10 meter, ot an 11.
Wonder hoe (exactly) they extended her?
Sectioned?
Still, not enough photos to be sure.
Sectioned?
- aaronbocknek
Clearly no one here on the Forum noticed the MR. FUSION adapter on top of the engines.
Once you get the 1.21 gigawatts from the Mr. Fusion, everything will fall into place.
Just not too sure about the prop pitch...
Actually I did notice that. But, I swear it's a thermo equalizer, coupled with a zeon cathode propelled by inert gasses compressed by the exhaust turbine, otherwise commonly known as a turbo. However, the waste gate linkage is probably loose at the knibbly pin...thus lowering the whole thrust factor to a minus 44. In which case, the boat will never do 28 knots at 1200 rpm!RWS wrote:Clearly no one here on the Forum noticed the MR. FUSION adapter on top of the engines.
