Last November I posted a thread introducing myself and told about my winter project of replacing the core in my front deck. This winter I removed the head and hull liner and stripped out everything above the V-bed in the forward state room. Well, the winter weather in Chicago was just too brutal to work on the actual core replacement, and I put the project on hold until spring. Well, spring is here and I’m finding the project slow going. Have you ever started a project and ask yourself “What have I done?â€
I am replacing the core from underneath and started in the nose inside the anchor rope locker. The core in this area was the most heavily damaged. The core was totally saturated and had turned to mush. The primary source was at the anchor deck plate. Trojan used a hole saw to drill a hole through the deck, but didn’t glass the exposed balsa core. They probably caulked around the core, but it was gone before I bought the boat. When I cut through bottom layer of the fiberglass, water ran out. Once water gets into the core it is trapped, with no way of getting out. The balsa wood soaks it up like a sponge and spreads through the core. Once the water reached the cleats they got loose and more water was able to get in around the base of the cleats. When you look at the core through the bottom layer of glass, anywhere the core is wet, it looks dark. It looks dark in the area where the anchor chocks are located and around the hatches.
This picture shows the dark area around the front hatch. When I removed that area the core had collapsed and was no longed supporting the deck. There was a soft spot in the deck in that area. The core next to the soft spot was wet but still in tact. The core towards the bottom of the picture was dry and was in great shape, but I removed it anyways.
To maintain the shape of the deck, I put in 2 x ¾†white oak bows. I am putting in the bows every foot. I started with a piece of 5/4 x 2†white oak and ripped it in thirds. This gave me 3 pieces of oak 2†wide and ¼†thick. The ¼†thick pieces were able to bend and follow the bow of the deck. Once the 3 pieces are laminated with epoxy it forms the 2 x ¾†bow. Here is a picture of the core replacement and white oak bows.
I applied epoxy to all joints in the balsa core. I opened the joints, first width, then length, and brushed a generous coating. When the joint closed epoxy squeezed out of every joint.
To apply the epoxy to the bottom of the deck I mixed microballoons to the epoxy to thicken it. I then used a 3/16†notched trowel and coated the bottom of the deck. I also applied the thickened epoxy to the balsa core. When the balsa core was pressed into place, epoxy squeezed out from the sheet. I don't have any pictures of this step because my hands were covered with epoxy, and I didn’t want to get any on the camera.
Working over head is difficult, time consuming, and messy. Everything has to be propped while the epoxy dries. The boat has to be covered to protect it from drips, but the work is progressing.
When I got to the hatch I found that the plywood that is laminated into the deck needed to be replaced. It took a bit of doing to get the old pieces out. I set the new pieces in epoxy and ran the white oak bow in front and behind the hatch. I also ran a piece of oak between the bows on either side of the hatch.
I'm almost done with the core in the front state room. I will be applying the glass to the core soon. The thickness of the bottom layer of glass was about 1/8â€. Trojan used their chop gun and sprayer a layer of glass on the core. They then covered it with a layer of woven roven. I’m thinking I will need to but two layers of 1.5 oz. mat, followed by a layer of woven roven. I used 7 sheets the balsa core to do the front state room and rope locker, plus 7 oak bows, each 2†wide and average 8’ long. Total area is about 70 square feet to glass. Over head glassing should be fun and a learning experance.
I'll continue to up date as the project progresses.
Back in November before you joined there was some discussion here about doing the job, you can look for it by scrolling back.
