Trojan Hull numbering and TRJ Numbering
Re: Trojan Hull numbering and TRJ Numbering
What’s mine?
TRJNF016L485
TRJNF016L485
1985 Trojan International 11 Meter Sedan
- Moderator
- 2026 Support
Checking on it ( sent mess to Bob ) What do you think you have ?
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
- Moderator
- 2026 Support
Do you have the other number ? Its in a ID plate inside normally on or near the electrical panel
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
I’ll have to look, got that off the survey.
- Moderator
- 2026 Support
You have a 85 11 meter sedan NL is the model . Model # 371 hull # 5016 371-5016 would be the other number I was referring to. Beacon marine has the original invoice for your boat . It is included in the owners manual package .
viewtopic.php?f=1&t=2695
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
M.V MuckAbout
Hi:
I am new to the forum and new to wood Trojans. Can anyone help with a model# 452? I know the boat is a 1970 36' Sedan Bridge but I cannot find anything on that specific model#. It is 452-0022 Made in 1970 and the 22nd hull...that's about it.
Thanks in advance!
Thanks in advance!
- Moderator
- 2026 Support
Welcome What do you need to know ? if its ID info contact Bob at beacon marine , If its boat questions post it on the the ForumM.V MuckAbout wrote: ↑Wed Sep 23, 2020 6:02 pm Hi:
Thanks in advance!
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
Hello Moderator,
Am I reading this correctly?
I'm about to purchase this Trojan with this Serial number TRJ31541272-251
Boat model year is 3, Hull serial number = 164, Manufacturing date = Dec 1972, Model number is 251 or F-25
Thanks,
Jun
Thanks,
Jun
- Moderator
- 2026 Support
Yes I believe that is correct , Bob would know for sure .
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
Wow!!!
My very first post here after finding you guys! I'm rather excited. So, I just bought what I thought was a 71 Trojan F32, but I only got to do a quick walkthrough and didn't have a camera with me, etc. At the moment, I'm four hours away but will see it again Sunday evening. In the meanwhile, this is the hull number I have to work with:
TRJ053480475
Tried decoding this with the references here, but I'm goofing something up, or somehow it might be missing part of the hull number from the USCG registration. I don't have the doc with me, only this. What should this decode to?
TRJ053480475
Grab and post some pictures of the boat and that might help us identify it regardless of TRJ number.
- Moderator
- 2026 Support
TRJO = Trojand3w4yn3 wrote: ↑Fri Sep 24, 2021 9:32 pm Wow!!!
TRJ053480475
5 = Model year 1975
348 hull number
0475 Certification date April 1975
There are 3 more digits that follow that #(on the transom) that ID the Model. There also another number on the ID inside Its likely located on the shore power panel. about the size of a cc. As posted a photo will help ID the Boat also
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
Okay, an update.... and yes, you were right, of course, but I had to hang over the water and almost drop my cell phone in the Atlantic trying to get a good enough shot of the hull number!
It is:
TRJ053480475-321
Which now includes those last numbers you mentioned! So an F-32 sedan!
Thanks for the clarification!!!
It is:
TRJ053480475-321
kbellflower
Ok looking at a Trojan 10 meter, was looking at the info on this page, but it doesn't seem to be making sense for what I'm seeing on the transom. Boat I'm looking at HIN is as follows:
TRJEHV12L586
any assistance or info would be appreciated.
TRJEHV12L586
