Backfiring engine losing power
lewglo
Post by lewglo »
We are new to this site - but have a 28' Trojan with flybridge. We have 318 Chrysler engines and have had trouble with both. Two mechanics have worked on them and neither seems to know what the problem is. Had a compression test which was good. Trouble with starboard engine we hoped has been resolved although not able to test it yet - mechanic replaced several parts and put a new electronic ignition in. While he did this he suggested we replace the port one as well, so as not to have any future trouble. This was after having to replace the starter on the port engine. Unfortunately this engine now backfires and loses power as soon as you put it under load. It will idle all day at the dock and will motor at about 7 knots on way out of harbour. As soon as it heats up for a few minutes it backfires and there is no power. Anybody had this problem, we would certainly love to hear from you - we are really at our wits end with this - this is the second year in a row we have not been able to use the boat - and we have spent a tonne of money on trying to resolve the problem. Until we can get the port engine problem rectified we cannot test to see if the starboard engine has actually been fixed. Thanks for your help....
sluggo
I dont know much
Post by sluggo »
but when I went through backfire issues it was always water in the fuel.
so I would check my water/fuel seperaters. On mine there are 2, a 'big one' that is from the gas tank into the engine, and a 'liitle' one that is in the carbourator. I did change the filters in my big one several times, to really no advail. I found that not all the parts where in the filter system, and when I replaced them, everything seemed to work fine. if it were me I'd start there.
Sluggo
87 10 mid cabin
Ohio river
Torcan
Post by Torcan »
Many things could be wrong
some that come to mind are:
Ignition timing incorrect
Damaged valve springs or sticking valves
vacuum leak
intake air (vacuum)leak
water in fuel
too rich?
http://www.cbyc.ca/
BarryL
Post by BarryL »
Spark plug wires out of order?
kallen
Post by kallen »
Remember the K.I.S.S it rule.
1- firing order
2- timing & advance total
3-spark plugs & wires ( proper routing of wires)
4-Timing chain play ( no more that 8 degrees)
5-ballast resistor voltage
6- coil voltage
7- carb float level
8- fuel pump pressure test
9- fuel filters
10- ignition control box
We are assuming that good parts were installed by your mechanics & that the distributor is correct.
+1 on Kallen
k9th
Post by k9th »
From my little bit of knowledge, it sounds like the answers already given pretty well cover it.
Welcome to the forum.
Did It do it before it was worked on ? If not start there ,
Jfreeman1412
Post by Jfreeman1412 »
Water in Fuel
Coil may be bad.....It will act good until it heats up and will go bad.
Try here....http://www.marineengine.com/boat-forum/ ... rive-Forum
Lots of experts that are willing to help.
Jfreeman1412, did you get straightened out with your distributor - got the answer you were looking for on that site? :shock:
Jfreeman1412
I have got a ton of advice and knowledge....I will be heading out to the boat this weekend and hopefully will have some answers for everyone. Still need to find out if my distributor is advancing, but will find out this weekend.
tunatamer
Post by tunatamer »
I would. Check the distributed. The old ones have system where the more the elms increase the mechanism turns and thus advances the timing. If this isn't turning as the rpm increased the timing will be thrown off thus creating a backfire situation. I'm actually a marine tech. And have come across this on.older vessels with the original distribiter. Hope this helps. Josh
Capt josh
Jfreeman1412
Hey Josh
When you replace the original distributor, do you just set the base timing or do you set the advance? And a shot in the dark.....Do you have the advance curve for the 318 marine engines?
What brand of distributor do you replace them with?
g36
Post by g36 »
although i am not capt josh
i replaced both of mine on my 78f32 318s with these. summit had a good price then you might look around and find them cheaper. both engine rotations on my 78 318's used the same distributor . the rotation is the same for the distributors on my engines. and as i recall i set at the 5 degree mark .
http://www.summitracing.com/parts/MAA-YLM579AV/
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
jefflaw35
Post by jefflaw35 »
nice add G36, a bit pricey but im going to look araound like you said. I still need a new one. Thanks for the input!! :D
