Question, clockwise counter clockwise motors
K4282
Re: Question, clockwise counter clockwise motors
Post by K4282 »
I replaced port motor only with original, as far as I know transmission with a FWC 318, drop in, plug and play in a RWC 1973 F32 sportfish
Is it clock wise looking at the front or back ?
summer storm
Post by summer storm »
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
Doug , trying to see how he is viewing the direction
Still not clear on what trans he used
summer storm
roger that, what a mystery
Doug
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
K4282 wrote:I replaced port motor only with original, as far as I know transmission with a FWC 318, drop in, plug and play in a RWC 1973 F32 sportfish
I reread this a few times and if its the original trans being used then it would have to be the same rotatation for the trans to work unless the pump was rotated .
K4282 is this the trans that came with the boat ? And if it was did you use it as is or rotate the pump ?
K4282
Post by K4282 »
I haven't had time to look into exactly what I have going on but took this fun picture last Friday night Image
Whatever way the engines turn the props when looked at from stern should both turn over the top to the outside of their respective side of the boat.
BTW I am not sure the intake manifolds for the 318 Chrysler are always automotive. Mine which are 3 degree slant for carby are cast MARINE on bottom. Perhaps the 11 degree slanted manifold may be pure auto. The 3 degree ones are used on vee drives and 11 on standard.
