Crusader 454 needs priming to get it started
- P-Dogg
Re: Crusader 454 needs priming to get it started
Holy ship!
Glad things didn't turn more tragic. Thank you for sharing your story. Sometimes our life lessons are hard to tell due to the resulting insult to our ego. I know mine sure are.
Currently Trojan-less
- WayWeGo
My Chrysler marine engine manual recommends using a pump oil can of gasoline to fill the carburetor float bowl through the vent tube before starting. Not sure I would do that...
Our last boat had a Mercruiser 454 with a Rochester Quadrajet that was always difficult to start if laid up for more than a day or two. Lots of cranking was needed, to the point that I had to wait and let the starter cool down a couple of times. Wish I had known about the fix Jamie mentioned.
I have 1984 454 350's and had the same cranking problem described throughout this thread, I bought a matched pair of remanufactured Quadrajet carburetors and it instantly fixed the problem, the boat starts almost instantly and both engines run smoothly with little exhaust smell. I still have the the pair I pulled off if anyone is interested in a good rebuildable set.. I'll sell them cheap !
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
