Shower pump- F32- 1985
Shower pump
So far I just switch the hose from shower to bilge under the sink. I have all the parts to make a manifold so I can switch from either bilge or the shower but so far it is still on my to do list. It certainly could be used to pump the keel but I am still a bit uneasy about drilling the hole into the keel, with my luck I would miss.
Drill the hole Andy
Drill, drill, drill
I can almost be certain there is water in there, and nasty water to boot.
And there really is some therapy in drilling into the hull of a boat (but its not really the hull just a fake.......
I tapped and found the hollow center its really quite wide back by the engine compartment maybe even 8 or 10" wide. I used a dremel tool to cut the front open and hole saws to cut the rear in the engine room.
This pic if forward looking aft at the bow
