Detroit Diesel 671TI Rebuild
- alexander38
And we lost all that info of King Pauly working on the 1st Godspeed with Capt. John Smith.
sorry about posts, but reall sorry about your back. Been there, done that, had back surgery - now I'm VERY careful how I left.
Best of luck with your back and the engines.
Sorry about your back... been there, done that. For me it only took 2 years of massage therapy and chiro to get things under control.
Slightly off topic but a couple of related questions to your rebuild : how many hours did / does the engine have on it, what kind of fuel consumption / burn rate were you getting, and what is the weight of the boat?
I am starting to get the itch to move onwards and upwards... the wife and I have been looking (at listings anyways) at some bigger boats, and some of them have mid-80's vintage Detroit 6-71TIs. I am certainly not a diesel guy, so looking for any info I can find to help educate myself. I have read a few different opinions re how reliable the TI series are given the high horsepower vs displacement (one post saying they need major overhauls every 1500 hours?), and I am trying to get a reasonable understanding of fuel consumption. The boats we are looking at are potentially in the 40,000 pound range.
Jerry
Hello all,
It's been a rough past 6 weeks or so as my back is still giving me issues and I am having health issues with both of my parents so not much progress has been made with the engine.
I have been able to get the bores measured, honed, measured, honed and measured.
They cleaned up nicely and I only ended up having to go with .002 oversize kits so I was happy about that. They were also perfectly round so that was a plus.
Most of the parts are here now so the next step will be to do the final fitting on the sleeves, then pull them back out to load. We are going to fit them a bit tighter than they were from the factory.
Before installing them, I have decided to install new front and rear main seals along with new main bearings so I will get that done before the final install of the kits.
Hopefully, things will start to move along now. Summer will be here before we know it!
Jerry
I forgot to mention,
Pretty interesting the way the pistons look. They are two piece design with a seal between the pieces.
There is a slipper bearing that goes on the lower part of the piston pin hole, and the connecting rod bolts to the piston pin with two small bolts.
I guess they can get away with that because these are such a low rpm engine.
I will post some pics so you can see what I am talking about.
Jerry
All of the sleeves were fitted then removed. We will do the final install once we are done with the main bearings and front, rear main seals.
To get to the rear main, we had to remove the flywheel. It sounds easy but that thing is very heavy.
We unbolted the engine coupler and used two of the mounting bolt holes to bolt a bracket that we made. We then attached a strap type come a long to the bracket to support the weight once it was removed.
Here is a pic of the flywheel once removed.
We just kind of pulled it out of the way then tied it off.
Pic of seal in rear of engine
