Max rpm 2800
Geoff R
Post by Geoff R »
Captin Ross
Primary .101 sec.086 rod .061 x .053 economy
Primary .101 sec .101 rod .062 x .052 4000 rpm
calibrated for economy it will not just hop out onto plane. But She will do it even after the admiral has packed for two weeks away but it can be a struggle
Good luck
Geoff
Thanks Geoff! You've got V-Drives, right?
Larry - got these #'s? Want to rebuild your carbs Monday? or is Wed better (after the dinner cruise)?
plansea
Post by plansea »
I hope i dont double post i lost my last post to cyber space. Thanx Geoff. You mentioned parasitic loads in an earlier post, don't think i have ever heard that term.. I checked my cutlass bearings last fall during haul-out,and i think my packing is right. Is there anything else i need to check?Again thanx ,Ross for all your help and friendship. It really matters! I got the carb info, lets shoot for wed. Larry
Goeff - when the engines are idling, the shafts rotate slightly, so I doubt if there is any drag whatsoever, but a good thought!
Wed. it is! The NAPA on 17 may have those Marine carb kits ...
Geoff R
Post by Geoff R »
I once got the # 1 & 3 plug wires mixed up on one engine when replacing the plugs . Ran great ! idled smooth as silk, no apparent miss. But would not get up on plane. Its a big step gettin up for the tri cabins. The hole behind U at 15 kts is about 5 ft deep.
Also if someone messed with the props B 4 Larry got it they are that close on power gettin up could be a problem
again good luck
Geoff
We've both been through the plugs wires, distributor, module, etc. "84 times" (in Larry's words), so go dto go there, but that can really mix you up if it happens.
Once we know the carbs are good, we'll take on the props.
Geoff R
Post by Geoff R »
rossjo wrote:We've both been through the plugs wires, distributor, module, etc. "84 times" (in Larry's words), so go dto go there, but that can really mix you up if it happens.
I haven,t had the pleasure of working on an engine under the cabin floor. Wat,s it like? pretty roomy
Easy on mine - inline 6 cylinder diesel provides a lot of room.
Larry's V8's are wider, and the tanks on the outside make it impossible to get to the starter on the port motor for example.
rossjo wrote:Easy on mine - inline 6 cylinder diesel provides a lot of room.
inline 6 cylinder diesel provides a lot of room ??? What ? There is a lot more room with a big block IMO , Maybe you don't have saddle tanks ?? on yours ( that would make a big difference I am sure
you should try to do my starboard stater as you can't see it , have do it by feel , the port water pump is fun too .
I would bet the cummins marine 6BTA with full marine trim is every bit as wide as the big block and a lot longer too
UPDATE the 8.1 crusader is listed as 32.8 wide and I am sure its wider then the 383/400 B block
the Cummins 6BTA is listed as 32.15" almost the same '
Now The Cummins 6BT is only 28" and I believe this is what Ross has so he would have more room and if no saddle tanks would be a big plus
Why the big difference between the 6BTA and the 6BT even tought the share the same block and head castings ? Its the add ons like after coolers and bigger heat exchangers turbo and so forth .
Well ... I have 6BTAs (listed in my signature) and have a lot more room than Larry's big block V8. The After coolers don't add any width.
I do not have saddle tanks.
I'm not a thin man, but I can crawl along the outsides of my motors to work on pumps, heat exchanger, starters, etc.
Geoff R
Post by Geoff R »
Wow !
This sounds like the difference Between fitting your elbow in without shredding it or not .
Saddle tanks and engines. Did they shoehorn a genset in there too ?
I have between 4-6 " from my starboard heat ex. to my saddle tank just enough to squeeze the starter through and its tight. the port side is not much better.
Sorry Ross I was thinking yours was a 210 or 220 hp not a 250 ?? sorry .Is yours a Cummins marine set up or a conversion by some on else ? I was thinking of photos that were posted a while back , maybe some one else.
Geoff R wrote:Wow !
They put it under the aft deck on the F36 , and shoe horn it on the F32 I think
The sadle tanks on the F36 do tighen things up for sure
bcritical
Re: Max rpm 2800
Post by bcritical »
How did this turn out did you fix it with fuel or props or something else. I have a similar problem only getting to 3300 but get full range in neutral.
