Exhaust Manifold Drain port plugs
Posted: Sun Apr 16, 2017 8:57 am
After chasing down my exhaust noise issue, I found it was caused by a missing exhaust drain port plug. Whew, nice easy quick and cheap fix (or so I thought)....
I pulled one out from another port to get an idea of the size and it would not go back in (now I need two!) After further inspection, it looks like the threads were mashed, or broken off inside the manifold. They appeared to be 1/8" NTP plugs, so I tried to run a trace through the threads, but it was not going in easy.... I stopped there and tried to look online for some specs, but I a coming up short...
My questions for the collective is.... What is the proper thread for the small exhaust plugs? And where can I source them? I am thinking that the yellow brass plugs have have now are not a good idea with salt water running through there....
