carb mystery
mr elevman
carb mystery
i have twin 318s thay bolth have edelbrocks and thair mounted directly to the manafold thay sit a little low by the angle of the throtel cable one cable end is allready broken the cable mount (factory)is higher then the carb linkage should thair be a spacer or a angled riser the manafold is pitched up in the back ive checked clearence from the top of the flame arester to the bottom of the hatch cover and thaires 3 1/2 inches clear area so a spacer could be added
