Water in oil
Posted: Sun Jun 15, 2008 12:01 pm
Hey guys,
For the last month I've been in Hell... So, here goes my sob story. I bought a Trojan F-25 Sea Raider (Sportfishing boat) from a real nice guy in Kent Island, MD. It was in mint condition (no kidding). Although... it's still a 1974 with a Inboard Mercruiser Ford 302 and 351 Windsor heads. I took it down the Chesapeake and up the Patomic on 24 & 25 April. She ran beautifully on the way home (168 miles)... besides a starting problem when she was warm... don't know why really but it doesn't matter now. Two weeks later. So... I figured I'd give her a tune up because it was starting rough and idling rough. I did the typical tune-up stuff... Then out for a test drive and all hell broke loose in my life!!! Twenty minutes into the ride I melted down the port side exhaust hose. Called Boat US and they towed me to Hampton's Marina. The owner of the Marina was a quality guy albeit his shop co-owner was a bit crass and well.. doesn't matter. What they found was Sea Cock 3/4 open, compression all screwed up... the receipt is at the boat right now can't give the exact numbers.. nonetheless... I towed it back to home marina...I took off the intake manifold, exhaust manifolds w/ risers, heads... everything down to the pistons. Yep! All gaskets were blown... head gaskets, exhaust gaskets, intake gaskets... you name it. I took the heads to a reputable machinist.. he shaved them but not enough to change compression and said they were good. I took the exhaust manifold & risers to Harbin Marine where they tested them and said they were good. I cleaned the rust up... rebuilt (basically) with new gaskets all around the exhaust manifold... risers etc....cleaned with wire brush all places a gasket would go... so new gaskets on everything.. using a certified mechanic to supervise me on the project. Ok. So, the engine is back together... tried to start... had problems with firing order.. got that right... started having an electrical short in the process. Shortening the days of headache story for you... I replaced with brand new parts... Thermostat, Thermostat sender, Thermostat gauge, starter, alternator, batteries, battery cables, rebuilt main water pump and belts.. electrical short still... found a good electric guy to coach me... had to bypass neutral safety start switch... still have a short somewhere but that's another issue altogether... I'm going to rewire the whole damn thing... but what I'm not getting is why I still have water coming in the oil. I've changed the oil 6 times... used motor flush twice... put sea foam in with several oil changes... I'M STILL GETTING WATER IN OIL!!!!... Oh! Let me throw this fact in.... we thought she was overheating but according to the new gauge she's ok at 160 to 180. However, the Starboard exhaust manifold is cool as a cucumber and the Port side will burn you. Also, while I was testing water flow I pulled hoses while running... what I found was good flow everywhere but the water going out the top of risers to overboard, the starboard side had much more pressure with some exhaust smoke in it... while I'm telling you this I must say that while the mechanic and I were putting the exhaust manifold (starboard) back on we slightly bent/kinked the new gasket... he said it wouldn't matter after putting gasket sealant (black stuff) and torqueing it down...but then again he's an auto mechanic... I've completely ignored my family/friends and work for three weeks while doing all this stuff... daylight to dark and beyond...She's running now but the valves are ticking bad (lack of good oil getting to them I guess) but probably I need to go back and adjust them again anyway as the mechanic didn't seem to do it right... but nonetheless.. oil gauge isn't working right now but never has.. I have a oil pressure sender unit on order, I already put a new gauge on. Still the BIG problem is water in the oil! I'm tired, beat down, financially wounded... In hindsight I could have put a new V6 Chevy Vortec in it with the same torque or more but that's another story... I've got 3500 in parts... labor, etc, etc ... It has beat me down guys... I'm at the mercy of all you guys at this point or pull the whole engine out (start over) when I save up some more money....and spend some time with my family... and am not so mentally beaten down. Can any of you magically bring me and Jezebel II back to life?
Thanks,
John Burnette
Ft. Belvoir, VA
Thanks,
John Burnette
Ft. Belvoir, VA
