Page 1 of 2
where does the packing go?
Posted: Mon Mar 19, 2012 5:16 pm
by antlr-king
i think i have the ones that are supposed to drip. when we bought the boat back in may the starboard one dripped the port side one did not. i figured today i would take them apart to see whats what. i couldnt see any packing. where does it go? here are a few shots of what i have.
you can also see all that oil has been cleaned up and the bilgecoat is finished.
Posted: Mon Mar 19, 2012 5:54 pm
by captainmaniac
Here's a good set of pics of the parts and process.
http://www.pbase.com/mainecruising/stuffing_box
Posted: Mon Mar 19, 2012 6:00 pm
by larryeddington
Check or replace the hose connecting the stuffing box to the through the hull. Mine had deep cracks in them and if failure guess what comes to the boat. :(
Posted: Mon Mar 19, 2012 7:29 pm
by antlr-king
i was thinking about that also. i will be taking that hose off to inspect thanks.
Posted: Mon Mar 19, 2012 7:34 pm
by antlr-king
hey thanks for that link. the packing goes into the nut. i have the nuts off. i can dig out the old packing but the nut has to be on the shaft to put the new packing in?.
Posted: Mon Mar 19, 2012 8:55 pm
by Big D
Yes, insert the packing into the nut when it is on the shaft. You won't be able to insert the shaft into a nut that has new packing in it without damaging the packing in the process.
Posted: Tue Mar 20, 2012 12:33 pm
by lawyerdave71
WOOOOOW HOLY MOOOOLY
What a great job you did on your bilge!!!!!
Posted: Tue Mar 20, 2012 12:38 pm
by lawyerdave71
By the way since we have the same boat - you are correct that they are supposed to drip - about 10 drips per 60 seconds - I can check the manual if you would like.
Posted: Tue Mar 20, 2012 4:31 pm
by antlr-king
yes thats what i heard also. i cleaned up the nut and took out the old packing from the port side one that wasnt dripping. does that look right? only 3 loops of packing is all thats needed? i still have to get the flange off the starboard side and do the same thing. also inspect or i guess replace the rubber. the hose clamps are rusted and it just doesnt look good. damn this project is getting expensive.
Image[/img][/url]
Posted: Tue Mar 20, 2012 4:34 pm
by antlr-king
do i have to pull the shaft out of this assembly to get the rubber hose off?
Posted: Tue Mar 20, 2012 4:39 pm
by antlr-king
:evil:
Posted: Tue Mar 20, 2012 4:42 pm
by larryeddington
Which means pulling coupler. That is the hard part
Posted: Tue Mar 20, 2012 4:44 pm
by antlr-king
nothing has been easy yet.
Posted: Tue Mar 20, 2012 4:58 pm
by larryeddington
Here is wha I used to get my shaft appart:
http://www.trojanboatsforum.net/wforum/viewt ... ght=puller
:idea:
Posted: Tue Mar 20, 2012 5:26 pm
by antlr-king
thats what i need. ill borrow a puller from auto zone next time go up to the marina. got a few days of engine work at home to do the next couple days. then friday i have a job. first one since middle jan. (self employed construction) business has been bad so far this year.
