1976 Trojan 30' Questions???
I have a 1976 30' Trojan and I pose a couple of questions...
First, what is the model of my boat(I will post a pick)?
Second, I have chrysler 318's and wondering If I am able to put chevy engine in thier place and will they be compatible with my transmissions? If so any good leads were to obtain them?
Thank you very much!!!
Karl
Karl
Karl
displaying pictures on this forum
To post your image, you need to upload the picture somehwere on the web, and have a url that locates the image. Then enter the url between the img tags
goes after the url
like this
[img]http://image_url[/img] (except there should be no spaces between the img tags and the url)
here is a sample url from a picture of a 1975 Trojan 30 Flybridge Express Cruiser advertised on boattraderonline.com
http://images.traderonline.com/img/6/de ... 8658_1.jpg
There are a lot of places you can upload the picture, like http://www.webshots.com after you upload, right click the picture and select properties from your browser to display the url. You can copy the url from the properties window.
When you enter the url as shown above, between the tags, (with no spaces) it will display like this below: (use preveiw before you post to confirm you got it right)
like this
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
Lots A Luck
Trojan F-26 Express
Is this it?
1975 F30 express.
Look at
https://www.trojanboats.net/zencart/ind ... x&cPath=66
scroll about halfway down the page look on the right side
1975 F30 express. Look at
formerly
Lots A Luck
Trojan F-26 Express
Lots A Luck
Trojan F-26 Express
[imhttp://boats.com/listing/gallery.jsp?entityid=13849711&showDL=false&showMD=false&galleryBack=%2Flisting%2Fboat_details.jsp%3Fsearchtype%3Dbuy%26showDL%3Dfalse%26showMD%3Dfalse%26back%3Dsession%26entityid%3D13849711%26searchid%3D1g]
Here is a boat the same style as mine...any help???
Thank you!
Karl[/img]
Thank you!
Karl[/img]
Karl
Thank you!
Karl[/url]http://boats.com/listing/gallery.jsp?en ... archid%3D1
Thank you!
Karl
willietrojan
Trojan 30'
I also own a Trojan F-30 but it is a 1977. I also have twin 318 Chyslers. I have been told by the marina that I can replace those with twin 350 chevy engines. I have not checked on this as so far I am happy with the performance of the 318's.
I just replaced my 318s with 2005 5.7L MPI PCM 350s and had only one problem and that was the engines sit higher than the 318s this would not work with the BW velvet drive trannys due to the rotation problem you know if your engines are right and left hand rotations all new engines are right hand so the trannys got to do the counterrotating so I went with hursh trannys
wow what a differance the new power made going from 318s with 225hp to 350s with 330hp I gained 6.5 knt and went from .6MPG to 1.2 MPG
