Synthetic Lubs for the LM383's?
Anyone have any intell on whether to switchover to Synthetic Oil for the engines? I have fantatic results from my vehicles but no prior experience with using it in marine engines.
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
I've seen some good debate on this matter
Personally, I'm old school
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I only know how clean the syn lube has made my Chevy Truck. With 100K miles on the clock, the oil is still amber 3k miles after it was changed. Since a marine engine is subject to a whole different stress level, I wanted to get some more reseach before jumping in .
aka "Basket Case"
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
I use reg. oil my self dive most my vec to 200,000 miles no proplems see lots of vec that got 300k or more use reg oil .
asfar as oil staying clean it has more to do with the engine runing clean then the oil . in fact a oil not doing its job maybe why its clean . a oil that get dirty is cleaning you engine .
Here's my 2 cents. I've used Wolfheads syn-blend in all of my fleet trucks from Ford and Chevy sb to international 444's and one is a 98 with over 400k on it. And changed my merc 454's when we bought the CARVER and have not ever had a oil failure or change over leak.15-40w
Maybe king Paul but the syn blend works well for me and with fleet trucks and my boat engines work hard and I feel better.
When I said that the oil in my vehicles was still amber after a couple thousand miles since the oil change that was many years since the syn lube thoroughly clean out the engine of all deposits. in the beginning when I switched, the oil had to be changed more frequently because it was black from cleaning out the entire inside of the engine. That's one of the best parts of using syn lube. Now many years after I switched, my engines don't have a chance to get dirty again so the oil is always amber right up until the point I have to change it. I only wanted to know if our hard-working marine engines would also benefit from the syn and it sounds like "yes". Thanks all.
Steve (risctaker)
Steve (risctaker)
aka "Basket Case"
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
The problem that most people encounter when switching a high mileage car or a marine engine with alot of hours, to synthetics is due to the detergents in the synthetic oil. The conventional oil "gunk" accumulates around the gaskets and other places, often times preventing leaks. The synthetic oil begins to remove this "gunk" and things like oil pan gaskets, main seals, and valve cover gaskets beging oozing oil.
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
' Goomar '
I find no advantage to synthetic other than cold starting at -40. at those temps it really shines I actually lean toward the SAE 30 or 50 in the summer. I can wait for it to warm up.
36 trojan tri cabin
http://s1116.photobucket.com/albums/k57 ... ?start=all
Captain Blast Off
I run a fleet of heavy duty diesel trucks from class 8 down to F-250 and personally have not found a suitable replacement for a good quality oil and regular service intervals; just not willing to bet any of my motors on it.
Guess I'm old school like Ron but we log over 2.5 million miles a year and we do not lose engines. Instead of synthetic blends if you really want to spend the extra cash do an oil sample every service, it's money better spent.
Steve
Steve
I don't see the need for the extra expense providing a good quality regular oil is used, checked and changed regularly. Unless of course it's a newer application and recommended by the manufacturer.
