The little Black Box
Ken
I have a the orginal owner's manual that came with my 77 F-26, but most of it is applicable to all Trojans from that year. I can send you some of the pages in pdf if you send me your email address, or let me know what you are looking for. The F-28 was a great looking boat. Not that many were made/sold, but it's one of my favorites. (Yeah, yeah, all you F-32 owners....yours is pretty too!!)
Mine is rfpssp@aol.com
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Asked the service guys at my marina and it turns out that my black box was removed years ago, before I had actually purchased the boat (1998). In the "old days" it looks as if my Tricabin had 1 battery per motor and these batteries were located at the front (toward the bow) of each v-drive. The black box no doubt came in handy in those days, as a 2 battery boat is just asking for trouble (IMHO).
When I bought the boat, the previous owner had updated to 2 batteries per engine but there was no black box, although the red "emergency start" button is still up there on the helm. I have since updated the charging system and have converted to two large battery banks controlled with a 3 position isolator switch..... and hopefully have battery power out the ying yang (famous last words, huh?).... but no black box.
.....now I did have a friend once who claimned he had a "little black book".
Rick, you have some nice toys in your list
I don't think my little 26ftr came with one, the little black box that is.
Info@emaltd.com
Info@emaltd.com
I switched over my boat to double banks controlled with the standard 1-2-all-off switch backed up with a Blue Seas ACR - works great. Basically the ACR automatically checks that the start bank will not get drained if I leave the switch on "all" by mistake. Now I just leave it on "2" (House Bank) all the time and never, ever worry about running out of juice to start the engine. I upped the house bank to 250AH which is more than enough for the F-26 to run on battery power for at least a weekend on the hook. Came in very handy on the canal trip when sometimes we just pulled up to a wall with no power (I did take the Honda 2000EU) just in case).
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Randy, Are you still in the Mohawk, if so how long? I could make the trip to show you my little gem.
Info@emaltd.com
Info@emaltd.com
Ken,
As everyone else has conveyed, the black box does parallel up both starting batteries when cranking. I had thought this wasn't the case and was corrected and validated it as well through testing.
I would keep it. Have not had a problem with mine.
If you send me your email, I can help you with a manual as well.
Steve
Steve
Steve Gajkowski, 1979 F32 in Sodus Bay, NY
62seaskiff
sehord
obeejr is right... it is an emergency switch that allows the two main starting batteries to be paralleled in the event that one of your batteries (or both) get drained. My 33 calls it an emergeny start switch. I wouldn't remove it. Things like that do indeed fail, as do alternators, air conditioning compressors and the like. But, Trojan engineers had a better idea of this boat than did your appraiser. And, of course, none of us ever have bad batteries, or been caught in the rain, or forgot charts, etc,etc, etc.....! Leave well enough alone and enjoy your boat. (If you do decide to remove it, do a voltage test o make sure that you have not altered or crosed your wiring to any other circuits in your starting system.....!)
I know I have one because the batteries ARE ALWAYS tied together during cranking, however I don't know where it is located on a 10 meter. Anyone know where it is ?
Also, FWIW, OK - what is the DIFFERENCE between the little black box, which engages AUTOMATICALLY and the emergency crossover toggle switch on the dash which connects the port and stbd batteries together?
The box is always energized by the battery connected to the engine you are starting. If that battery is completely dead, it won't parallel in the second battery, so you still have no starter power. The toggle switch on the dash allows you to select which battery is used to energize the box, so either up or down should parallel the batteries and get your dead engine started.
Whenever I have had a dead battery, I started the "good" engine first, before I used the dash switch, so I don't have to worry about draining both batteries.
I also have a separate house bank and a generator- but stuff happens!
Little black box
If you look at the volt meters when cranking you should notice that both meters show a voltage drop. So even though only one switch is on both meters will register.
Re: Little black box
Not on mine or my last one . the volt meter is after the switch and will not read un less tthe switch(s) are onlakeguy72 wrote:If you look at the volt meters when cranking you should notice that both meters show a voltage drop. So even though only one switch is on both meters will register.
