F26 Bow thruster
- alexander38
Just a basic knowledge test. The way I see it you can make all the laws you want a the only thing you do is get the govt deeper in your pocket and life and won't fix a thing. If a guy can't dock his boat then I hope he can write checks.
alexander38 wrote:Just a basic knowledge test. The way I see it you can make all the laws you want a the only thing you do is get the govt deeper in your pocket and life and won't fix a thing. If a guy can't dock his boat the I hope he can write checks.
I have always said If a guy can't Fix his boat the I hope he can write checks. Thank goodness I can fix a boat cuse the checks would bounce
Paul you and I can both write checks! Just whoever recieves them better not drop them huh? Thats what I'm doing with my slip renewal!!!prowlersfish wrote:alexander38 wrote:Just a basic knowledge test. The way I see it you can make all the laws you want a the only thing you do is get the govt deeper in your pocket and life and won't fix a thing. If a guy can't dock his boat the I hope he can write checks.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Is it possible that rsciolino, the guy who started this post, is considering installing a bow thruster as insurance against "bang the s<#& out of their boat, the dock, and other peoples boats just to get in or out of their slip?" After all, isn't it better for him to spend his money on his own boat as opposed to spending it repairing someone else's.Allen Sr wrote:Tony, is it just a basic knowledge or skills test to? I know a while back in another post there was discussion about it and a link to it. IMO if its just basic knowledge thats really no good, (better than nothing I guess). How many times have you seen people educated way beyond their intelligence just bang the s<#& out of their boat, the dock, and other peoples boats just to get in or out of their slip? And just didn't care?alexander38 wrote:We're getting there Va. is fazing it slowing with age time lines..![]()
I have one of these boats and have learned how to get it in and out of tight spots and more importantly, how not to get into places that I shouldn't be. There are days when I'm in a tight marina with the wind and prop walk working against me while backing into a slip. On these days a bow thruster would make thing easier since I don't have twins to pivot with. For me however the loss of storage space wouldn't be worth it just to have another toy on the boat.
To answer rsciolino' s question, on this boat it would have to be located forward of the bulkhead mid way in the V berth. Depending on the type you purchase, you may have to notch out the plywood that supports the insert cushion for the dinette when not in use. Keep in mind that batteries give off explosive gases when charging and discharging so you might consider mounting it in the engine bay where there's ventilation. Be sure to use the appropriate gauge cables.
lower cost thruster
The Sideshift mentioned earlier by captainmaniac is a real easy install. I installed a stern unit on a trawler that had no room for a through transom unit. It was a piece of cake to install. I did not hang it off the swim platform as shown on thier web site, rather, I bolted to the transom. Four bolt holes and a hole for the cable which is hidden behind the tube/mounting plate. The manufacturer here in Ontario was great to work with. You give them the length of tube you want and they build to your spec. It has been in use for three years and the owner is extremely happy with it. I personally think a stern thruster is better than a bow unit, after all, we steer by shifting the position at the stern not the bow. The single screw wants to torque the stern one way in reverse, the best place to couteract that is at the stern. As for the cost, unless you're really good at glass work yourself, and figuring out the geometry of where a bow unit should go, you'll easily eat up the savings for a regular unit in the installation alone.
Yes, but the main point (I think) is that a lot of people want or need bow thrusters because they think they can drive a boat like a car, and steer from the front. When the bow doesn't just go where they turn the wheel, they think they need help to push it (instead of learning the dynamics of the boat and working with that).Big D wrote:I personally think a stern thruster is better than a bow unit, after all, we steer by shifting the position at the stern not the bow.
Oh, and by the way - the 36 Trojan I saw the Sideshift on the bow of -- was basically the same model as yours (+/- a year or two)!!!! The owner (allegedly) has a quarter million in upgrades in it (including a couple of diesels that apparently cost 60K each, Stidd helm seats, extended bridge, Glendinning Cablemaster system, custom swim platform, and other upgrades), everything done in a way that it looks like it belongs there.... and then this Sideshift hanging off the bow.
I do think its neat having both bow and stern thrusters . makes for easy side to docking . But I will stick to no thrusters . I also love being told you can't get your boat in( or out of ) there and then do it . I love squeezing in at the fuel dock I go to . the others boater go in to a panic as I put My boat where they think it wont fit ( between 2 boats ) . The dock hands just smile cuz they know me .
One of life's simple pleasures
yes I am a trouble maker
- alexander38
Your a PITA too.
