Steering Cylinder
Diverted Income
Steering Cylinder
Post by Diverted Income »
One of my many projects needs to include the steering. I meant to snap pics of the cylinder but didn't get that done. Anyway, I need to remove the cylinder and replace the the seals. Does anyone know what the fittings are on the cylinder? Compression, AN, or hydraulic fittings? What about size? I want to pull the lines and couple them together so I can service the cylinder and want to have a shot at having the right fittings to do so!
Thanks!
82 F-32
DOUBLE R
Post by DOUBLE R »
Check your cylinder rods. Chances are they are a bit corroded or scored, and if so a new unit is called for. Also, they tend to be corroded togetther at the end where it is supposed to unscrew and is next to impossible to get apart.
MY CURENT FLEET
2003 KEY WEST 2020 WA
1978 ASHCRAFT 14' SKIFF
one of many reasons I upgraded the helm and cylinder from Hynautic to Sea Star during the refit
He maybe ok as there is not much salt water in Iowa
DOUBLE R
Post by DOUBLE R »
prowlersfish wrote:He maybe ok as there is not much salt water in Iowa
Good point, Prowler.
MY CURENT FLEET
