No water flow
lakewind69
No water flow
Had the engines rebuilt on my 1969 30" Sea Raider. Ford 302 Interceptors. Starboard engine is fine...runs great. Problem is with the port engine. No water flowing through cooling system. New impeller installed. Have checked hoses on the outlet side of pump and found no blockage. Any ideas? Lake Superior is calling...help!
Re: No water flow
Pump on backwards or hoses . It would be different then the other engine ( diff rotation )
Re: No water flow
plastic bag (or growth) in the scoop or ball valve
happened to me
the bag was compressed into the size of a half a lima bean.
happened to me
lakewind69
Re: No water flow
Thanks for the advise. After 1&1/2 years on the hard, I went back and looked at my pre engine removal pictures and noticed the port intake was incorrect. Switched them and everything is fine now. The forum comes through again! I'm try to send some pictures.
Re: No water flow
Photos should be easier to post nowlakewind69 wrote: ↑Sun Aug 26, 2018 3:22 pm Thanks for the advise. After 1&1/2 years on the hard, I went back and looked at my pre engine removal pictures and noticed the port intake was incorrect. Switched them and everything is fine now. The forum comes through again! I'm try to send some pictures.![]()
