hatch slider knob
hatch slider knob
on my f32 assuming these are original. i have on my hatches a round threaded disc that you tighten on the slider to keep the hatch up. they all are functional but sometimes i'll have someone open the hatch and think the disc is tight and then it will bang shut later. i would think something that would be easier to grip would make tightening this a little easier. maybe with a knurled type knob or similar. i had thought about installing a piece of rubber in between that would compress to help. has anyone replaced these knobs or modified the originals somehow? i just started looking but thought i would ask.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Re: hatch slider knob
Sounds like your discs are missing. Mine have a plastic disc either side of the arm... the knob is then able to compress it somewhat and likely has more friction than metal to metal. It is rare for mine to close even when underway.g36 wrote:on my f32 assuming these are original. i have on my hatches a round threaded disc that you tighten on the slider to keep the hatch up.
Rich Schwochow
In the slide bars on mine have three indentations that hold the hatch up. The knurled thumb nut justs holds things together. Actually they are more difficult to close cause you have to back off the nut, lift the hatch then lift the bar and hold it clear as you lower then hatch. All while trying to sit half up in the "v" berth.
1989 F-32
Penetang,
Georgian Bay
Penetang,
Georgian Bay
