Starboard ignition switches start port motor
I have a 1979 Trojan 32. When I try to start the starboard motor the port starter engages. It has been intermittent for a couple of years but now consistently misbehaves. I am planning on replacing all ignition switches but wanted to see if anyone had any other suggestions. Motors are Chrysler 360s ARCO starters. Thanks in advance.
Re: Starboard ignition switches start port motor
Sounds like the diode for the emergency/parallel start system is going bad.
https://www.trojanboats.net/zencart/ind ... ts_id=1379
Thank you so much for your help. I guarantee you saved me another 10 hours of tracing wires.
Glad to help.
- P-Dogg
You can buy the manual for your boat from Beacon. Highly recommended.
https://www.trojanboats.net/zencart/ind ... cts_id=615
