89 mid cabin alternator and belt size
mrrudely
Post by mrrudely »
replacing starboard alternator
it is a one wire
does anyone have a part number?
I found mando 39200
prestolite 39064
Motorola MR
also current belt size is 47 5/8" which seems a bit long
thx
rr
10 meter mid cabin
Re: 89 mid cabin alternator and belt size
Any photo of your Alt? Beacon Marine has some
https://www.trojanboats.net/zencart/ind ... th=102_110
Scott67
Post by Scott67 »
mrrudely wrote: Tue Apr 02, 2024 1:45 am replacing starboard alternator
it is a one wire
I found mando 39200
prestolite 39064
Motorola MR
thx
rr
Assuming your engine serial number is greater than 88710, the alternator numbers you quoted are correct and my recommended replacement would be an Arco 60104, $191.59 through Amazon.
Regarding the belt size, again assuming serial number greater than 88710, the correct belt part number is Crusader #98210
"Speakeasy"
Model 340
Twin 454 (350hp) Crusaders
1.5:1 Gearboxes
Jacksonville, FL
mrrudely
Post by mrrudely »
thanks guys
serial number is 76868
I bought a DB Electric from Amazon
Looks like it will work, I'll Let you know if it doesn't.
As for the belt, that crusader number gives me a spec of 49 1/8" which is too long.
I will use the old belt as a guide.
rr
10 meter mid cabin
