generator parts
sweet E mocean
generator parts
Hey ! can anyone tell me where to get onan parts ? i have an onan 6.5kw with no data plate and need parts.. HELP PLEASE
Don't know where you are but this will help, do you know the year of the genny?
http://www.google.com/search?q=Onan+gen ... tartPage=1
Cummins should be able to help... as you have no data plate you may well have to take the old parts with you or look on them for some numbers.
What kind of parts do you need?
According to Cummins/Onan:
If you can't find or read the nameplate, you can find a serial number stamped on the generator set.
Call the Cummins Onan Customer Response Center with the serial number at 1-800-888-6626. Press 3 when prompted by the recording. They'll help you identify the model and spec letter you need to order parts and manuals. If you can't find the serial number on your set, they can help you determine where to look for it.
If none of the above helps you identify your Cummins Onan generator set, please contact your local Cummins Onan distributor or dealer.
Without nameplate information or a serial number, you may need to have a Cummins Onan dealer in your area look at the set to identify it. To find the nearest location, use the Cummins Onan Dealer Locator or call 1-800-888-6626 and press 1 when prompted by the recording
Gerry
1979 F36 Twin Chryler 440's
