Help!!! I cant get up on plane
I moved my recently purchased Trojan 30 from Winthrop Ma. to Warwick Ri. this weekend. I had to fill up 3 times in 200 miles.
My top speed was only 15 at 3800rpm. Clearly something is out of wack.
It plowed like a torpedo the whole way.
Any suggestions?
Any suggestions?
I just went in. Bottom is spotless as well as the running gear. Prior owner said trim tabs are in fixed position but he never had a broblem getting up on plane. I was on this boat last year and have to vouch for that.
I'll check the timing and see if that helps at all.
Thank you very much for the quick responses guys!
- guglielmo6160
if you were taching at 3800 I doubt the timing has anything to do with it,you should be crankin at that rpm, are both your engines doing that?
are you nose heavy, stupid question but bilge water???? sounds strange, are your transmissions engaged, meaning, any slippage ? dragging anything, last year with my old boat I had a similar problem, getting back to my marina for 45 min, when I got there, there was a log stuck under my boat, near the outdrive, I didnt see it till I got there the next day
I feel my current boat has a problem with getting up on plane, but Im always reluctant to push my ford 302's past 2700, until I can trust them fully, I just purchased the boat and have not hauled it yet. Alot of advice here was given to me regarding hauling and cleaning the bottom, but you mention your bottom is fine,
so not sure, it can only be a few things, Im sure youll get the problem,
either not enough power, slipping trans,, or your dragging something, overloaded??? how much weight were you carrying
doubtfull your trim tabs are causing this, they would have to be in the extreme down position and even then, you would overcome most of that, but double check, ya never know
Last edited by guglielmo6160 on Wed May 06, 2009 10:27 pm, edited 3 times in total.
1983 10 meter express
Its not the timing . your getting 3800rpm so the engines are turning up . I asume both engines are ? with a clean bottom and turng 3800 you should be mid 20s at least with out tabs if the where all the way down it could cause the boat to plow badly and slow you down . how loaded was the boat ?
Your description of plowing tells a lot. For the nose to be plowing says loading in the bow, or trim tabs. Lack of power or drag you should be bow high and not be able to get on plane. In rough waves I trim nose down to reduce the bow slapping it doesn't take much trim tab to get to that configuration not even close to full tab down.
Dan Faith
Toy Box
Trojan F32
Trojan 30' sport fisherman
Sea Ray 17'
Beach Craft Bonanza N35
Corvette
Toy Box
Trojan F32
Sea Ray 17'
Corvette
- guglielmo6160
I agreeguglielmo6160 wrote:mmmm interesting, I thought the transmissions were either engaged or not engaged, its not like a clutch, how were they not "fully" engaged, just curious,
thanks
If they were half engaged and sliping they would have burnt up in 2 mins. I would be pretty hard to get it between engaged and not ,and both of them ?? ( if twins )
and if sliping your RPM would have been a lot higher
- guglielmo6160
Moon Dance something's not right here , both trans ? same time ?
were the props pulled and reinstalled recently ? and maybe put on the wrong side and instead of changing them they just reversed the shift cables ? that would cause problems like you may have . velvit drives dont that well to this
Make sure when you put the boat in forward gear the leavers move forward on the gear box
I have seen this a few times
