laminate wood flooring
My significant other has laminate in here beauty shop in the water around the wash sink water all the time with no problem. I looked at using it in my galley but problems with it you need to leave a 1/4 in expansion around the perimeter. slippery when wet and I need to be able to put in inspection and access to the bilge. Also if you need to take up it would be nearly impossible. That is why I went with teak and holley plywood, screwed down so I can take up plus it gives me additional strength between the stringers and ribs (laminate only lays on top and can move possibly giving you a spongy floor)
Dan Faith
Toy Box
Trojan F32
Trojan 30' sport fisherman
Sea Ray 17'
Beach Craft Bonanza N35
Corvette
Toy Box
Trojan F32
Sea Ray 17'
Corvette
Wow this seems to be a hot topic!!
I read elsewhere that some one used it in the salon area, only big issue was the floor access panels to the hot water tanks, water pumps and bilges. they had to ad braces and cut down the panels so they could finish the perimeter of the floor panels with trim. they counter sunk the chrome hatch handles. It looked reallly nice.
I was on Lowe's web site and they sell a couple laminate flooring products that are water resistant and are designed for basements.
kevin babineau
This is just one of the flavors, "GUN STOCK", but there are more
http://www.homedepot.com/webapp/wcs/sto ... 0003+90401
kevin babineau
wet wonder
My brother used the Pergo type laminate in his basement. His hot water heater sprung a leak and covered the floor with water. The base of the strips, under the laminate, absorbed water and warped. Most of the laminate strips ended up buckling and the floor had to be redone. I think it's OK to use if you accept that in the unlikely event that you take water somehow that the strips will be damaged. This is why I chose to use the vinyl wood look strips.
1975 Trojan F-25 Express Hardtop
Mercruiser 351 233hp
12v system - Solar panels 170 watts
Another good option is to use marine grade plywood with a laminated finish. I bought teak and hollow finished 1/2 " marine plywood from World Plywood in FL. I then used the old floor section as templates. Then I coated the bottom of each new section with epoxy (varnish would probably do also) to waterproof the side that would face the bilge. Then I varnished the teak/holly side with 3 coats of semi-gloss. That was 8 years ago and it's held up great. I'll probably re-varnish at the end of the season.
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
kevin babineau
Yea, but in a boat your not talking a lot of square footage. I figure my salon to be about 12x 12 at the largest. That's $120+shipping. That's affordable.kevin babineau wrote:that stuff is awesome.....i guess it depends on weither u can afford $9 a square or $2.50.....i love it with the holly
Now if you did a room in your house it could get expensive but even then, that cheaper than some tiles.
It's not a bad price really.
79' Carver 28' Mariner
kevin babineau
