switching from a manual to electric head
Dont know the brand, but I have a manual pump toilet. wanting to change over.
l looked in a couple catalogs and they sell the complete setup or u can buy a converstion kit. with the kit u use the original toilet and only replace the manual pump unit.
Either route I go, on a rating of 1 to 5 how difficult is this to do.
RARITAN160HF912
Raritan 12V HOUSEHOLD,FRESH,90DEG
This is the model I installed. Replace yours and you'll wonder why you didn't do it sooner.
http://www.raritaneng.com/products/toilets/index.html
Easy as 1-2-3
Easy as 1-2-3
kevin babineau
it all depends on time and money......if it was me id do the conversion ....i would assume the hardest part will be getting power to it...not the mechanics of it...but it all depends on how your old one wants to come apart..either route u take
Last edited by kevin babineau on Wed May 27, 2009 1:52 pm, edited 1 time in total.
Complete replacement, Sea Era, household style. Go new complete if you can...gofish103 wrote:did you do a complete replacement or the conversion??
what model is that?
It uses fresh water.
I have the same one you can go with fresh or salt water but I would go for the fresh water modelStripermann2 wrote:Complete replacement, Sea Era, household style. Go new complete if you can...gofish103 wrote:did you do a complete replacement or the conversion??
what model is that?
kevin babineau
