fuel pump question
guglielmo6160
fuel pump question
Post by guglielmo6160 »
as a mechanic, I think I already know the answer to this question, but I like asking you guys as you know your boats, better than I ever will, so heres another question
I have two mechanical pumps on my ford 302's my question is , I ran out of gas on my port engine, and it took a long time to re prime the carb bowls,
what do you dudes think of installing a couple of electric pulse type fuel pumps in series , before the mechanical pumps as a sort of priming set up? I mean its easy enough to do, and I can even set it up where I can install a series of bypass valves and hoses that I can use as an emergency run set up in the event of a mechanical pump failure, any thoughts?
1983 10 meter express
jav
Post by jav »
why not a priming bulb circuit?
Dan Faith
Post by Dan Faith »
I will work and you can if properly installed use it in the case of a mechanical pump failure. This is the set up on my airplane, a mechanical pump supplies the fuel in normal operation, to stop the engine the lean mixture is pulled and this runs the engine carb or injection system dry. To start press the electrical pump to prime to start, if you run tank dry switch tanks turn on electric pump and start (takes too long for mechanica). If failure on mechanical pump just turn electric pump on full time operation. A lot more critical in the air than on the water costs could be a factor and find an electric pump that is explosion proof for marine operation.
Dan Faith
Toy Box
Trojan F32
Trojan 30' sport fisherman
Sea Ray 17'
Beach Craft Bonanza N35
Corvette
ltbrett
Post by ltbrett »
I ran with that set up for about a season. My port mechanical pump failed due to cam wear and I put an electrical pump in series before it. I made the repair just prior to taking a party underway, so I left the old pump in place until I got around to removing it. So yes, it will work. But then you must ask yourself why have a mechanical pump in the circuit at all? I wired in cranking relays, so if you crank the engines a couple of times then pause, the electric pumps kick in and prime the carbs. Fires right up, even after being left for a week or two in December.
Brett
guglielmo6160
Im going with the electric pumps, I have had bad luck with the mechanical pumps when you run out of fuel, the electric pumps work great and are a snap to change, if they fail, just carry a spare and you can change iti in a matter of minutes
g36
fuel pump
Post by g36 »
i was curious i dont need to do anything with my pumps at the moment but a couple of posts earlier dan faith made a comment about the electric fuel pump being explosion proof, has this been addressed in the pump that you are going to install?. also for future reference whats the make of the fuel pump are you going to install? i havent had trouble with my mechanical pumps so i dont know if i would ever switch but there does seem to be some issues that need some attention if switching
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
Dan Faith
Post by Dan Faith »
Any electrical equipment in the engine room must be Marine grade. In industry we called them explosion proof (No external spark). This is the same as not using a car fuel pump in a boat.
Here is a link to a couple replacements.
http://www.101part.com/fuel/fuel-pumps/ ... marine.htm
http://marineengineparts.com/shopsite_s ... age81.html
Dan Faith
Toy Box
Trojan F32
Sea Ray 17'
Corvette
Safari
Post by Safari »
I keep a Carter marine electric pump permanently mounted that I use as an emergency backup (never used) and to pump fuel off at the end of the season. This pump replaced an expensive Holley pump that leaked. My experience is that mechanical pumps are extremely reliable. If you replace them every 10 years, you will probably never experience a failure. One thing to consider is that carbs require low pressure (maybe 4psi); electric pumps can deliver 40psi so you will need a regulator.
Electric fuel pumps will run whenever they are switched on, which can lead to extremely dangerous situations if there is a leak due to mechanical fault or an accident. Mechanical fuel pumps are much safer, due to their lower operating pressures and because they 'turn off' when the engine stops running.
Bill
1986 F36 Crusader 454s
wvorris@hotmail.com
They make low pressure marine electric pumps .the 40 psi pumps are for FI not carbs
Dan Faith
Post by Dan Faith »
They also make a safety switch that, should be used, put in with the oil pressure unit that shuts down the electric pump when the engine is not running.
Dan Faith
Toy Box
Trojan F32
Sea Ray 17'
Corvette
guglielmo6160
safari
the pumps your referring to that produce more than 4-5 psi are used for fuel injection, there are numerous pumps that supply the exact pressure that a mechanical pump produces between 4-6 which are commonly used for carbueretor float type set ups
in regards to a fuel pump working only when you turn it on is inaccurate, an electric pump should ONLY be installed with a relay system that will only activate the pump during engine crank and run situations, it would be foolish to install an electric pump that runs with the engine off' and I disagree with a mechanical pump being reliable, I have had nothing but problems with mechanical fuel pumps , and I do this for a living, so I can tell you with confidence that electric fuel pumps are far more reliable than mechanical, in my opinion,. but its all a matter of opinion. I just like the idea of being able to prime my enignes faster when I need to. and the replacement of an electric pump is far quicker than mechanical. and much much easier to diagnois.
and G36 carter makes a marine grade fuel pump which does not spark, but there are also many other plastic body solid state pumps which are safe as well,
remember, do you think an automotive electric fuel pump will spark??
I think not
guglielmo6160
Dan Faith
Post by Dan Faith »
I will disagree with the use of an automotive fuel pump in a marine application, Why do you think they make marine grade fuel pumps? Also a general statement of electric fuel pumps being more reliable is too general a statement. I have had six electric fuel pumps in my corvette installed and gauranteed by a Chevy dealer, never had a problem with a mechanical pump. Also have had local mechanics change over electrical to mechanical pumps due to problems. But I would never make a general statement as to one being better that the other.
Dan Faith
Toy Box
Trojan F32
Sea Ray 17'
Corvette
Dan Faith wrote:I will disagree with the use of an automotive fuel pump in a marine application, Why do you think they make marine grade fuel pumps? Also a general statement of electric fuel pumps being more reliable is too general a statement. I have had six electric fuel pumps in my corvette installed and gauranteed by a Chevy dealer, never had a problem with a mechanical pump. Also have had local mechanics change over electrical to mechanical pumps due to problems. But I would never make a general statement as to one being better that the other.
I agree you should us marine grade pumps . I made a lot of money off mechanical pumps in their day now I make a lot off electric pumps .what do I think is better ? To me its a toss up they both have pros and cons .
