running aground
blackyvanhorn
running aground
Post by blackyvanhorn »
HI
I lost my prop and bent my rudder after hitting some unmarked rocks along the shoreline in the howe sound south of squamish. Luckily, I found my prop the next day, but I did not find my prop nut. The prop shaft is "1. Does anyone know where to find a Prop nut. I also managed to straighten my rudder. Any precautions I should take when installing the rudder back in place to prevent leakage.
thanks
I am fairly new 68 trojan owner. 28 ft of wood
You may want to repack the stuffimg box . make sure the rudder shaft is turning true if its not it can cause other damage. check with bob here at trojanboats.net on yourprop nuts or your local prop shop. I sure top will need work you need 2 one thick one thin. what about the key ? I would check the prop shaft for being bent . Its not normal to lose a prop when running a ground .
guglielmo6160
Post by guglielmo6160 »
you found your prop?? ya gotta be kidding,? what kind of shape was it in, and how the heck did it come off??
1983 10 meter express
LSP
Post by LSP »
I was thinking the same thing....
Will - LSP
1976 F32 "Donegal"
1985 10 Meter "Whakanui"
Hog Pen Creek
Middle River, Md
I wonder how long the prop nut been missing ? remeber it needs 2
guglielmo6160
that was a really odd posting,,lol
aaronbocknek
Post by aaronbocknek »
i would check the rudder stock tube to see if it is cracked or bent. i had a situation this spring with what i thought was a leaking rudder stuffing box but upon further investigation, it was discovered by the mechanic that repacked it, a bent rudder stock plate and a cracked tube that was patched with what looked like jb weld or marine tex. the 1/4" brass plate that is welded to the stuffing box was actually 'waved' and could never form a water tight seal on the backing plate. i have pics in my camera if anyone is interested in seeing this. i think what peeves me the most is the surveyor did not even notice this last year when i bought the boat. it was replaced with a new assembly and the back bilge is dry as a bone.
aaron
aaronbocknek@gmail.com
