10.8 macerator
10.8 macerator
I have a 1989 10.8 innternational and was hoping someone could help me with a macerator question. Many people talk about having a y valve in order to operate their macerator. I looked below by the macerator pump and only see a sea cock to open. I also know that the panel board has a pump out toggle switch. My question: Does the 10.8 have this y valve or do you just throw the toggle switch and open the sea cock? I also understand where permissible!!!
As I recall, the factory setup allows the macerator to pull waste from the tank and pump it overboard.
There should be a tee fitting downstream of the macerator in the event the deck fitting is used at a pumpout facility.
My 1983 10 meter express cruiser (not mid cabin) has no "y" valve, just a tee fitting.
Gerry,
You are correct, my downstream/upstream error!
The tee is between the tank & the macerator.
Make sure you have a TALL LOOP IN THAT MACERATOR HOSE TO THE TOP OF THE ENGINE ROOM to be sure of anti syphon issues.
