Orinigal wall paper removal
- Bob Giaier
My wife and I are in the middle of rebuilding our new (new to us) 73' tri cabin. I call myself the laborer and she of course is the decorator. Her plan is to make the boat look like the 70's styles. I'm not exactly sure what that means.. but I'm hoping she doesn't use too many peace signs and flourescnent light posters. Anyways, she is trying to get the wall paper off the walls. In most places it just pulls off, but areas like the walls in the aft head and the wall directly opposing the aft cabin stairs/wall, the stuff won't come off. I'm trying to let her do here thing while I pull fuel tanks and rebuild the aft deck. You know heavy labor stuff that has to do with whether the boat floats or runs. I guess the decorating is important too.
Any suggestions (on the wall paper removal) would be appreciated.
Peter
It's a horrible job. I found that a heat gun doesn't really help because it makes the vinyl tear more easily. I guess it depends on how anxious you are to get the old stuff off. Using the sharp corner of a paint scraper while applying traction to the vinyl will SLOWLY remove it, if you don't mind spending hours, and hours, and hours [ and it takes good hand strength]. On the other hand it's quicker to fabricate new panels out of 3/8 plywood for the covered panels. Can also, in other areas just cover the old stuff. Can't really use wallpaper to cover the old stuff because the original vinyl is textured [and the pattern will show through]. By stapling new vinyl covering along the edges, stretching very well, using trim to cover the staples you also get a very nice effect.
I recently bought some marine vinyl, [leftovers] for a song, and it looks awesome. [About halfway done the master stateroom]
you can also paint over the old vinyl [not first choice]
good luck
good luck
If the heat gun is used sparingly it will loosen the glues stick without softening the vinyl... I do agree it is a lot of work to pull it off and then the cleanup of the wood base becomes even more of a chore... so if the existing surface is not full of tears do what I am doing....
I am just covering my old vinyl with new as the surface is undamaged but just old looking.
They make wall paper remover. It works OK, but theres really no sortcut to the elbow grease method.
If done carefully, oven cleaner may work ... but be sure to ventilate (for your health).
- Bob Giaier
We covered our old vinyl with new vinyl wallpaper last weekend... my better half said it was no problem.
Purchased the vinyl paper from Home Depot and the lady there said to just treat with vinyl size to prep the old vinyl surface.
Going back up next week and will try to get some photos... 'tis a small space so they may end up being meaningless.
Once she did the paper she decided the old counter tops and backsplash looked pretty bad (which I had removed to make the papering easier to hide behind joints) so they are now at my local counter top joint (as templates) along with new marine ply and I should have new one's by the end of this week.
My new composting head arrived yesterday so I will be getting that setup too.
and now it will never stop.......
- Bob Giaier
Just a follow up on the idea of using a heat gun. We did try the heat gun last week and it does work. The problem now is that we have allot of glue residue left on the wall. We tried sanding with a mouse sander with 80 grit. We blew up the sander. Seems like there must be a better way. I'm considering a belt sander on it now.
Your experience is one of the reasons I concluded that the best route was to cover the old as it did not have major damage.
How thick is the glue residue?
How thick is the Vinyl paper you are putting on the wall?
Is it a smooth finish or does it have some surface structure to it?
Will applying vinyl size and new paper not hide these imperfections?
Our new paper had a surface design pattern which hid any imperfections, even the seams of the old paper after we applied it.
I suggest you look at new vinyl paper with some surface structure and not worry about it........ I don't think a glass smooth finish to start with will give any better finished look to the area.
- Bob Giaier
Peter
I just finished redoing the forward stateroom with vinyl. I used Marine grade vinyl, mostly over the old vinyl paper, because of the nightmare removing the old stuff, the glue residue, and the bits of ply pulled off by the glue. I attached the vinyl with a combination of indoor outdoor double-sided carpet tape, staples, and 3M spray adhesive. Vinyl wallpaper will show all the substrate defects.
I'm now finishing the top of the closets, [which was covered in a horrible orange marble formica] with teak [jointed/planed today]. Good luck.
