Onan 6.5KW generator Electronic Ignition conversion
yes, you have the nub won't fit the gen-set hole, it's a real pain in the a$5 to get the allen bolt holes line back up.but just take your time.
sorry yes I cut the nub off, you could file it to fit the hole, but cuttin' it works
did you get the gen set done ?
Well,
I did get the carb rebuilt (Not bad to do) and figured I would run it with the old ignition system first to burn off the fogging oil. The generator would not start. Now I am not getting fuel to the carb inlet. I suspect that the fuel pump is bad. I ran out of daylight.
We have been rebedding the bow rail and I had to enlarge the hole and epoxy to keep form getting deck rot. I will get to the EIK later this week or next.
davidsmith
Fuel Pump
If you have the fuel pump shaped like a round pipe you can remove one end and remove the plunger. Clean the bore so the plunger slides easily. There is a strainer in the pump you can clean also. You should be able to shake the pump when finished and hear the plunger sliding up and down. Will save you $$
1977-F36
22`Aquasport
1969 18` Donzi 2+3
22`Aquasport
1969 18` Donzi 2+3
if your gas pimp is bad let me know I've got a place for the replacement for $113.00 bucks, mine went bad, also I'm replacing the head temp switch found that for $34.00
pegasusautoracing dot com item # 1107 Facet low pressure fuel pump is what you need.
LT Brett
On the midcabin, there is a 1/2" bolt welded to the stanchion that goes through the deck and is fastened with a fender washer, lock washer and nut.
What I am doing is enlarging the hole, filling with epoxy then redrilling the holes so that no deck coring can be exposed to water.
Thansk for the tips on the fuel pumps. Didn't get a chance to look at it today but I did find the facet fuel pumps on line for about $90. I wasn't sure if I needed the LP fuel pump or the silver top (1105). (2-4.5 psi) i think the latter as it is designed to run at 2psi and that is the spec in the Onan manual.
