83 Tri Cabin A/C compressor won't start
nitro115
Post by nitro115 »
Hi all, been a long time reader. I've had this Tri Cabin for 3 years only, and have moderate experience.
The problem: the forward A/C's compressor doesn't want to start. When I turn the control knob to Run, the lights get dim in the cabin, then after about 5-6 seconds they all come back to normal. When trying to start the A/C, the breaker doesn't trip at all. I've tried to hook up a hard start, but everything remains the same. I've swapped the relay, and the start and run capacitors between the two units I have, still no go. The air handler's fan runs okay, and I can hear the reversing valve working too when I switch between Heat and Cool. I'm afraid the compressor is shot, but I'd like to hear some opinions, since I'm not an expert at marine A/Cs.
Also, IF the whole unit needs to be replaced, where can I find one? It's a Crusiair Type J unit, 12k BTU, 115V model.
Thanks for any help in advance!
1983 Trojan Tri Cabin
k9th
Post by k9th »
Sounds like a compressor problem for sure. Since they are still in business, perhaps Cruisair has replacement units.
http://www.dometic.com/enus/Americas/US ... /Cruisair/
Sounds like a seized compressor but check the ends of your shore power cords and the inlets on the boat. Look for melted or burnt plastic around each contact.
nitro115
Post by nitro115 »
Thank you guys! I've checked the coils of the compressor for short and/or ground fault, everything looked good. I guess it's just locked up. Thanks for link, will give them a call. And prepare my wallet :-)
Thank you guys!
Old Flame
'83 Tricabin AC
Post by Old Flame »
No help on the AC, but just had to comment on your great looking Tricabin. Being shed-kept does help. Mine's in an open slip.
Good luck with the AC. Might be a good time to convert to digital controls.
Jim - 1985 36' Tricabin
"Old Flame"
Sassafras Harbor Marina
Georgetown, MD
nitro115
Post by nitro115 »
Thanks for the compliment, Jim! I've been trying to keep her in a good and preferably original shape. The digital thermostat has definitely great advantages, have been playing with that thought for quite some time. But then, I would need two. They're not cheap, especially not when the heat pump itself needs to be replaced as well. The wife approval factor (WAF) certainly has a major role in this decision :-)
Oh yeah, the roof over the boat is priceless. I feel lucky to be able to have a slip like that and under 3.5k at Lake Norman, NC!
