varnish vs oil
stevocom
varnish vs oil
Post by stevocom »
teak varnish vs teak oil, pro's and con's of either please.
jddens
Post by jddens »
This topic has been discussed in many past posts. You will get positive and negative comments on both processes....it boils down to personal preference. I'm in the teak oil camp, easy application and natural look. down side is you have to do it 1-2 times a season. Upside....easy prep (wash with stiff brush and tide laundry soap with bleach paste) nothing to peel and natural look.....you will get many more responses.............John
1998 Kawasaki ZXi 1100
messed up post.. never mind...
Last edited by captainmaniac on Wed Jul 14, 2010 11:17 pm, edited 1 time in total.
Oil - short term, but looks most 'natural' for the teak. Expect to re-oil every month or two. Varnish - longer lasting, less 'normal'. There are other options as well such as Deks Olje, and Cetol. Different looks, different lifespans, and also depends on climate etc. I use varnish on aft rail (Interlux Goldspar), Cetol on most other wood (that takes wear and tear), and Cetol with Cetol Gloss on my pulpit. Wheel is Epifanes no-sand varnish. For all of them - anywhere from 4 - 7 coats. Usually get 3-4 years before any sanding/re-coat necessary.
Here are pics with my results
Wood Finish examples (part 1)
https://www.trojanboatsforum.net/wforum/view ... f=1&t=3206
Wood Finish examples (part 2)
https://www.trojanboatsforum.net/wforum/view ... =1&t=12738
stevocom
Post by stevocom »
I often wonder if varnish on the bridge ladder would be slick when wet. I have young children i worry about up and down the ladder.
For rungs on the bridge ladder : Varnish - slippery - don't do that. Regular etol or most Teak Oils, less slippery (the most non-slippery solution is to do nothing and let the sun bleach the &%^()# out of the rungs... or coat them with some rubberized composition. Safe and non-slippery yes, but looks like crap in my opinion..) Best middle ground (again, in my opinion) - Cetol (either 'original' or 'light', but don't use 'gloss').
k9th
Post by k9th »
I have varnish on the outside teak and use oil on the inside teak. That is the way the boat was when I purchased it a couple of years ago. I don't think I have the energy to remove the varnish although I prefer the natural look.
You're right, my swim ladder is a little slippery when wet.
foofer b
Post by foofer b »
Your post said one or the other, so forgive me if you have ruled it out, but painting it with two part polyurethane (epoxy). It is very durable, and will last for up to 5 years in the sun. I finished my swim platform two years ago and sprinkled it with sand while the first coat was wet, painting over it on the second coat to make a wonderful non slip surface. It looks as new as the day I finished it.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
as far as varnish on steps You can put a strip of no-skid tape on it and it still looks good
as far as painting teak :( ugh
randyp
Post by randyp »
Cetol Natural. Used teak oil for years on the sailboat and it looks ok but doesn't last. Cetol Natural used on all exterior teak trim and swim platform (with non-skid added to next to last coat). This year I'm removing all the interior teak trim, doors, etc and will sand and varnish to several coats for a high gloss finish. I replaced the original cabin floors with teak/holly plywood and finished with 2 coats matte poly. Does not slip when wet. Will remove them also are refinish them the same way. The Cetol Natural on the swiim platform and exterior teak has lasted for 2 seasons. Any touch up is easy - sand where necessary and recoat once or twice as needed.
Randy P
1977 F-26 HT
"Blue Heron"
mtwolf
Post by mtwolf »
The teak inside my 73 F-31 was originally finished with Watco Teak Oil according to the original owners manual that I have. Watco can be purchased from home Depot. Directions say that it can be used outside as well as in. I refinished all the inside wood several years ago. About the easiest stuff in the world to use and provides a nice flat teak oil finish. It is really a resin. I use Cetol on my outside teak rails though. Oil just didn't hold up for me.
John
1973 F-31
foofer b
Post by foofer b »
[quote="
as far as painting teak :( ugh[/quote]
Down south here I boat 9-12 months a year and want something that holds up to the Florida sun. Plus I don't want to reapply every year.
MY CURRENT FLEET
297Elegante
Post by 297Elegante »
I have Cetol Natural, and Cetol Gloss for my teak. I have read good things and really like the ability to "patch" small areas as they claim.
BTW captainmaniac, beautiful teak work. Nothing looks better than well cared for teak on a boat!
Boat: Silverton 34C T/270s, Gen
sehord
Post by sehord »
I use teak oil on mine, but i have to redo it every 2-3 weeks.... am i using a cheap oil or is it just the hot florida sun on mine?
297Elegante wrote:BTW captainmaniac, beautiful teak work. Nothing looks better than well cared for teak on a boat!
Thank you! The best part of it all is that the job usually lasts 3-4 years before I have to do any maintenance.
