10M Express Deadrise?
crazyyankee
Does anyone know the deadrise of the hull? Buying a transducer, and I want to make sure I don't need a long shaft on the thru hull for a steep deadrise. My recollection is that its a pretty small one, but I figured I'd ask the experts.
it may depend on the location you are intending to place it.
My installation required a FAIRING BLOCK to get the transducer toshoot straight down, instead of on an angle.
From the inside of the boat, you'll find my 'ducer in the lazarette - on the stbd side, fairly close to the stbd stringer from center line.
If you are interested I can dig out the info on the 'ducer and fairing block.
I'm running a Ray Marine C-80 integrated chartplotter.
