refinishing railings, ladder to helm
Have any of you refiished your exterior wood work, if so what did you use?
Here are some examples of potential results. Bad idea to use Gloss on the steps the bridge ladder - gloss tends to get slippery when it is wet.
http://www.trojanboatsforum.net/wforum/viewt ... d+finishes
I did the following,
sand with 150, bleach and brighten with Teka or west marine two part cleaner brightener, (with port supply the westmarine brand is about 8.00 for the two part kit in quarts)
sand with 220
then 8 coats of Z - Spar polyurethane sanding with 220 between coat and a few coats every three or four months
sand with 220
