F-26 side windows
JonChristman
F-26 side windows
I bought some really good stuff for the plexiglass windows. The side cockpit windows and the two from windows over the bed up front were looking pretty hazing, and this stuff cleaned the right up and they are so clear now it is just great.
I did these windows all in place. it was a little akward around the throttle controles, but eaily managed. I then got this big idea to take out the side windows and do them too. Well I tried lifting them up from the outside and it just wastn't working. So I took out the whole frame. While looking down into the frame I notice all of the goock and nastiness that is growing inside of there. The little carpet like peices for smooth sliding are all moss covered and totally grotesque. I would like to replace these, but I am not sure how to proceed. The windows frames don't seem to have a way to come apart. I have the plexi glasse out and I am working on cleaning up the tracks. Any suggestions would be greatly appreciated.
Jon
Former Owner of F-26 "Tir Nan Og"
and looking for another Trojan
Re: F-26 side windows
Please enlighten us, what stuff did you use?JonChristman wrote:I bought some really good stuff for the plexiglass windows. The side cockpit windows and the two from windows over the bed up front were looking pretty hazing, and this stuff cleaned the right up and they are so clear now it is just great.
http://www.cbyc.ca/
http://www.cbyc.ca/
JonChristman
Sorry, I guess I should have shared...lol
The stuff is called scratch-off. I have a pilot friend who uses it on airplane windows. I bought it from AirCraft Spruce...
http://www.aircraftspruce.com/catalog/c ... tchoff.php.
It is several grades of polishing compund and drill mouted foam pads and you progress through until you get to final polish. There are six steps, but I started at step 3 for my hazy windows. But there are a lot of scatches on the side cockpit windows that I will actually start at step 1 which is to wet sand with 600 grit. But that will be a next winter project,
Jon
Have to remove the "dot" after the php on your linkJonChristman wrote:Sorry, I guess I should have shared...lol
won't work otherwise
thanks, will look into that for my side windows. Rooferdave may also be interested in this for his forward windows as well.
Thanks for the link
sorry I can't help you with your original question
Hopefully someone here will be able to help you
thanks again!!!
http://www.cbyc.ca/
http://www.cbyc.ca/
JonChristman
JonChristman
Thanks guys,
Bob at Beacon was able to track down exactly what I needed to replace the weatherstripping on the windows. In the mean time, I cleaned the tracks with bleach and small wirebruch and then soaked them with fabric softener. So they are clean and Snuggle fresh...
I am ready to get in the water so I am going to leave the pile wetherstripping replacement for my list on next winter project.
Jon
For those wishing to replace the cabin side window channel felt on the F26, here are a couple of options:
http://www.ultrafab.com/cart/
http://www.ultrafab.com/cart/images/ult ... _guide.pdf
http://www.amesbury.com/Divisions/Sealing-Products
Here is what I ended up using for my F26 cabin side windows:
http://www.crlaurence.com/crlapps/showl ... elID=12349
Bryan
Bryan
