Dead spot on the flywheel
Tri-Guy
Post by Tri-Guy »
I have Chrysler 360s with velvet drive trans. The flywheel on the port engine has a dead spot,how much of an azz ache is this job . Thanks John
How hard is it ? that depends on you skill level . you will have to unbolt the shaft and rear mount to stringer bolts . ( you may have to loosen the front )raise the trans and rear of the engine . (you may have to remove some hoses to raise the engine ) support the engine and remove the trans ( very heavy apox 150 lbs) . then remove the starter and the bell housing , The remove the flywheel and replace the ring gear ( heat and press on) . I can do this in a day no problem , But its the type of thing I do .
Is your starter a rear mount ? if it is pull it and see if the ring gear may be coming off the flywheel
Tri-Guy
Post by Tri-Guy »
Thanks Prowler I pulled the starter and two teeth were MIA, I think one was already gone. I can do the job myself just thinking about how crappy it is :( thanks
while you're doing the work think of all the good things you can buy with the money saved by DIY....makes me feel better every time I bust a knuckle. :wink:
Thats true . But only it if the job within your skill , knowledge and comfort level . I have made many a dollar fixing a owners or "Buddys " repair .
Tri-Guy wrote:Thanks Prowler I pulled the starter and two teeth were MIA, I think one was already gone. I can do the job myself just thinking about how crappy it is :( thanks
did you read WHAT HE said....it's in his skill level ....that's why I said what I said Paul.... :P
My reply was to your post and not directed to any one . I said that as I have seen people get over there heads .
He said he could do it and I don't have any reason not to believe him
ok then.... :P I'll go back to being good now.... :lol:
alexander38 wrote:ok then.... :P I'll go back to being good now.... :lol:
Never happen :roll:
Allen Sr
Post by Allen Sr »
TONY AND PAUL, BOTH of you play NICE or you will get a TIME OUT!!!!! :lol: :lol: :lol: :lol:
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
I find the biggest headache is lining up the tranny's input shaft splines to that of the engine. The tranny's wieght makes subtle positional adjustments difficult to do. The slightest angle off will make it impossible to insert. Be patient.
I use 2 longer bolts and slide it in place
Ya Paul, done that too. Probably the best way to do it.
And it still can fight you :cry:
Oh ya. Have a beer ready as soon as it goes back in!
