Bent Rudder Repair?
jcatkinson
Bent Rudder Repair?
Post by jcatkinson »
Is it cost effective to have a bent rudder repaired/straightened or should I opt for a new one? Finally got my F-26 on a trailer this week but unfortunately I set the bunks about 1/2" too low and the rudder hit a low spot in my driveway and bent about 20 degrees. Funny because there was no rudder to ground contact coming up the ramp. Good lesson learned.
Thanks!
I would give it a try ,what have you got to lose ?
GARYGA
rutter repair too
Post by GARYGA »
I just pulled my f308 from utah to new york on my trailor. i seemed to have bent a rutter as i bottomed out coming up the dirt road to my home. i dont have a solution for you but am interested in what you find out and what you decide to do. i was going to try and take the rutter off as i also need to reseal them and then send it out to be bent back. i believe mine are bronz because of all the green color on them. while im doing this im going to sentd one prop in to same place for straightening. good luck and i will be looking at your replys. gary ga
1981 trojan f308
IN THE HAMPTONS
My port rudder is bent ( rudder shaft ) I will try to straighten it .
I think your rudder is bronze with a SS shaft. (mine is )
Gary glad to see the boats home . how did the tow go ?
Lookout
Post by Lookout »
I just went through this. Cant fix em, but I wish you luck none the less.
  • LOOKOUT AGAIN
  • 1986 F-36
  • Lake Michigan Fish Slayer.
http://www.lookoutcharterservice.com
Danny Bailey
Post by Danny Bailey »
If you can get it out of the bearing assy, and if the shaft is bronze, you can straighten it in a hydraulic press. I did.
jcatkinson
Rudder
Thanks for the replies. Anyone happen to know the size of the
F-26 rudder/shaft if I do end up having to replace it? I'm going to price one out just to see what the going rate is.
randyp
Post by randyp »
I've got a schematic of the rudder assembly bracket, collar, etc from my F-26 owner's manual. I can email it to you (pdf). At least you'll know how it comes apart!
Randy P
1977 F-26 HT
"Blue Heron"
jcatkinson
Rudder
randyp wrote:I've got a schematic of the rudder assembly bracket, collar, etc from my F-26 owner's manual. I can email it to you (pdf). At least you'll know how it comes apart!
Thanks Randy I appreciate the info.
james_20_mil@hotmail.com
chucka
Post by chucka »
Anyone happen to know the size of the F-26 rudder/shaft?
Stock size is 1" dia. I upgraded to 1.25" dia a few years ago, and put on a larger rudder while I was at it.
One of my favorite tricks is to dig a hole in the ground under the boat (hopefully she is blocked up on gravel or grass, not sitting on pavement) to drop the rudder down far enough to remove the rudder shaft from the stuffing box. If you can't drop the rudder down below grade, you will have to jack the boat up pretty high to get the rudder out of the stuffing box.
Chuck [/quote]
formerly
Lots A Luck
Trojan F-26 Express
Narragansett Bay, RI
jcatkinson
Rudder
Funny you mentioned digging a hole. I was thinking the same thing today while looking at the poor old rudder. I'm on a trailer and on relatively soft ground so the "hole trick" seems like my best bet. I priced out a new rudder today at $300 and was informed the rudder on my boat is bronze with a bronze shaft.
jcatkinson
Rudder
I'm having a heck of a time getting the rudder out. I was able to get all the hardware removed with no problem. I was actually able to get the rudder to drop about 5 inches now she's being stubborn. I saturated it with liquid wrench and I'm hoping that will do the trick tomorrow morning. Otherwise I'm going to have to put some heat on it.
Did you loosen/ remove the packing nut ? also check for burrs in the shaft . I would think twice about heat theres fumes in the bilge
SHORTFUSE
Post by SHORTFUSE »
Make a lever out of 2 2x4s and bolt them together around the rudder,make the sandwich very tight.After you have it together have someone stand on the lever for down pressure and walk the lever back and forth.I did this with very good results.
jcatkinson
Rudder
prowlersfish wrote:Did you loosen/ remove the packing nut ? also check for burrs in the shaft . I would think twice about heat theres fumes in the bilge
All the hardware is removed, just have 32 years of salt/corrosion build up on the shaft making it difficult to remove. If I end up applying heat I'll torch it from the outside. I'll have my gas free detector and ram fan set up just in case.
