transmission problem on 11 meter express
Yachtski III
Hello all,
Just took my 1989 11 Meter Express on it's shakedown cruise - first time in the water for us together.
Engines ran fine but I had a issue with the starboard transmission - at least i think it was the transmission.
I could feel a hesitation - almost like we hit a wave.
When i went down in the engine room I could hear a 'clunking', which was random. (Not present in port transmission)
If i took it over 1500 RPM it got worse.
Once it actually stalled the engine out at ~1500 RPM.
There was a whining sound at around 1300 RPM.
This is the first time the boat has been in the water in two years.
I looked at the transmission fluid and it was not dark or cloudy - but i will be replacing it first thing!
Anything else I could check? Any other suggestions/ideas?
Yachtski III
thanks prowlerfish!
The boat just went in - first time in two years, so I doubt I have something on the props - of course, anything is possible.
It seems it was the transmission fluid - i did change it and had it out yesterday. It ran much better. (Plan on changing it again now that it has run some.)
While I suspected the transmission fluid I was hoping for other suggestions for me to address before taking it out and trying again.
BTW - both of the water lines to the drip-less shaft fittings were clogged at the engine.
Noise
Just a thought.. But on my old Crusaders my tranny made some intermittent noises/clunks but worked just fine...
When we removed the Bell housing we found part of a pressure plate spring floating around.
Regardless, there are several good rebuild shops if needed. Cant remember mine but I can get it if needed.
Good Luck
Patrick
Good Luck
Patrick
Yachtski III
Seeing as how you had some success with the fluid change. Check with the transmission manufacturer about Lubegard part #60902. It is a great additive product for transmissions that use Dexron. It is available at NAPA stores. We use it in our shop with all fluid changes with great success.
manners & civility are not a sign of weakness
Yachtski III
