thermostats
- antlr-king
thermostats
i need to pick up a couple thermostats for the 2 new long blocks. these are raw water cooled with carter carbs. what size thermostats would i need? 140, 145, 160? so many choices? lol
and so many dif price ranges also. i saw one for 84.00 dollars. whats up with that?
1979 30' trojan express
Captain Blast Off
I run raw water cooling in my boat and was told 140 degrees. The guy who told me said that hotter then that and you could begin crystalizing whatever minerals are in the water.
The manual calls for 140 but they are not available, atleast I could not get them, I used 142 from Beacon and should be fine. I had a discussion with Paul (prowlerfish) and learned that an thing much over 160 causes salt water to crystalize and do its damage much quicker.
Incidentally mine did not have any in it which was PO try to take care of over heat problems, the problem was stopped up tranny oil coolers, the water could not get by to the engine.
What engines? 140 Should be it. Here's another thread, if you're running Chryslers.
http://www.trojanboatsforum.net/wforum/viewt ... thermostat
- antlr-king
- vabeach1234
Make sure you get the right one.
There are two different kinds, one that looks like an automotive kind:
http://www.trojanboats.net/zencart/inde ... cts_id=413
And one that looks like something entirely different and just redirects the water.
http://www.trojanboats.net/zencart/inde ... cts_id=407
I think which kind depends on the intake manifold and how the cooling system is plumbed.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Hampton, VA
- antlr-king
davidsmith
I know on my chrysler 440 it will overheat with the wrong style thermostat no matter what temp. The outer brass secrion moves down to close off a passage in the housing to direct flow. Without a thermostat it will overheat in 5 minutes. Learned that one the hard way. OJT
1977-F36
22`Aquasport
1969 18` Donzi 2+3
22`Aquasport
1969 18` Donzi 2+3
Captain Blast Off
It was impossible to find the small diameter 140's for my old Interceptors; someone had used ones for $50 each (each engine takes two). I went to West Marine and found a 140 degree thermostat that had the same inside dementions as my old ones and then ground down the outer diamenter of the thermostat to fit.
Problem solved for $50 total all four thermostats and they"re new.
jefflaw35
"like" sorry made my own "like" button!!Captain Blast Off wrote:It was impossible to find the small diameter 140's for my old Interceptors; someone had used ones for $50 each (each engine takes two). I went to West Marine and found a 140 degree thermostat that had the same inside dementions as my old ones and then ground down the outer diamenter of the thermostat to fit.
- TADTOOMUCH
Thermostat
Look at http://www.marinepartssource.com and search for 142 degree thermostat. You will find they have them for around $17.00 each for raw water cooling. The chryslers with carter carbs use the 142 degree and the rochester carbs use the 140 degree.
Chrysler part number is 3527765
Boat Name: A TAD TOO MUCH
As long as we're not substituting automotive for marine t-stats; there are differences; by-pass ports, materials etc. Material wise, remember that some apps are raw water cooled, and cars don't have to deal with that or the corrosion (there's that word again) issues that arise from dissimilar metals. I also recall something about spring loading or direction to prevent overheat in a t-stat failure but that could be for all stats now.
Larry, the "top hat" design may be pictured in vabeach's 2nd link.
