Moderators: BeaconMarineBob , Moderator , BeaconMarineDon
antlr-king
Posts: 173 Joined: Thu May 26, 2011 1:52 pm
Post
by antlr-king » Wed Mar 14, 2012 6:29 pm
i have 2 of these. they have this sensor with 2 wires going to it on the side. what is this for? and if i wanted to replace it where could i find one? thanks
1979 30' trojan express
Posts: 12765 Joined: Sat Nov 05, 2005 6:56 pm
Post
by prowlersfish » Wed Mar 14, 2012 6:30 pm
Thats you neutral safety switch . It keeps you from starting in gear .
gettaway
Posts: 1142 Joined: Mon Feb 15, 2010 1:48 pm
Post
by gettaway » Wed Mar 14, 2012 6:31 pm
that would be your neutral safety switch, check continuity through both terminals in and out of gear.
1984 Silverton 37C
Silver Lining
Scott
antlr-king
Post
by antlr-king » Wed Mar 14, 2012 6:50 pm
ok thanks.
jefflaw35
Post
by jefflaw35 » Wed Mar 14, 2012 7:35 pm
Posts: 2878 Joined: Sat May 01, 2010 10:39 pm
Post
by Big D » Wed Mar 14, 2012 10:51 pm
Yup, neutral safety switch. If you know how to use an ohm meter, you should have continuity with the lever in the neutral position only. Continuity in any other position or no continuity in nuetral means a replacement. If you don't get a satisfactory reading, take it out and inspect, then bench test for continuity.
Eddie-O
Posts: 74 Joined: Wed Mar 23, 2005 11:51 pm
Post
by Eddie-O » Fri Mar 16, 2012 12:18 am
To remove it do you remove the plate or just back off the big nut that has the 2 termanels on it
Post
by prowlersfish » Fri Mar 16, 2012 6:40 am
Just unscrew it .
antlr-king
Post
by antlr-king » Fri Mar 16, 2012 7:11 pm
lol this thing looked pretty bad untill i cleaned it. yes i will check that continuity on that switch.
antlr-king
Post
by antlr-king » Tue May 08, 2012 7:27 pm
had to bring this back real quick. engines are all in. im going to buy tranny fluid and engine oil. how much fluid does one of these trannys hold?
antlr-king
Post
by antlr-king » Tue May 08, 2012 9:33 pm
i just found out. they hold 2 quarts.
Post
by prowlersfish » Tue May 08, 2012 9:37 pm
That can vary depending on the angle . I would put in a qt check and add some and recheck until you get it in range .
Post
by Big D » Tue May 08, 2012 9:50 pm
.....then run, shut down and check again. This will fill your lines and cooler.
