Portlight Installation
I had to pull one of my portlights on my 10 meter to repair the glass clamp mechanism. I had it fixed and now need to put it back in. Reading online there are a million products and just as many methods to put the ports back in. Does anybody have a method and preference of material for installation?
Thanks
Thanks
Tony just went through that process
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I've done 3 or 4 on my boat. The biggest thing I've found is you need to run a bead of clear sealant on the outside between the frame and portlight itself. That wasn't done from the factory and I believe that is a source of water in big waves, in addition to the seal itself.
I assume you just replaced the inner half correct? I also ran a bead around that using the same stuff before reinstall. That part is not as critical though as it never really comes into play if the outside bead is there.
Sure, you could use 4000 to do the same thing. You don't need 4200 or higher because the screws around the frame are the fastening part.
Bob hit it dead onBobCT wrote:I've done 3 or 4 on my boat. The biggest thing I've found is you need to run a bead of clear sealant on the outside between the frame and portlight itself. That wasn't done from the factory and I believe that is a source of water in big waves, in addition to the seal itself.
I recently replaced the round seal on one of mine (head) and have five more to go.
My question is .... how do you get them apart and then out to rebed them?
The fixed one in my closet is (pretty sure) leaking.
I wouldn't necessarily remove them to re-bed like other fittings on the boat. As long as you've run a bead between the frame and the portlight on the outside you should be set.
If you want to remove the inner half to replace the screen or run a new bead around the inside frame, just remove all the screws inside the boat and it will pull right out. The outer frame is secured with different screws so you can do this with the boat in the water.
I had visions of the whole thing falling into the drink the first time I did this and figured out how it was assembled.
- BlueBelle
I'm sure the 10M is similar to the 11M. The outside frame does not connect to the inner frame at all. Rather, the outside frame has tabs that screw in to the core between the exterior and interior fiberglass layers. Terrible design. When the frames begin to leak (and they will) the core gets wet.
If I recall correctly, the inner frame screws in to the inner wall of fiberglass. And yes, you can definitely remove the inner frame independently from the outer frame, with no fear that the outer frame will fall into the drink.
1986 Trojan 11M w/ twin JT671TI
are the 10 meter sides cored ?
- Mike Kulp
My mid cabin is just like what they are describing, I resealed all my port holes the factory sealant was old and brittle, I cleaned off all the old sealant used boat life sealant and put a large bead on the outer frame and secured it, wiped everything down then ran a bead between the two halves as i put them together to seal the gap between them that is very critical for a water tight seal. The project really was not that difficult in fact I installed the last port hole while the boat was in the travel lift headed for the water, nothing like waiting to the last minute.
Mike 1986 10 Meter mid cabin
