F32 prop shafts
phasev
F32 prop shafts
Post by phasev »
I have owned a F32 since 1979 with 318 Chrysler power. My prop shafts have a diameter 1-1/4". I found a guy trying to sell his spare set on the web with the same power but he claims his props are for 1-1/2" shaft. Did Trojan have two different diameter shafts for the same boat with the same power?? :?:
Not to my knowledge. Mine are 1 1/4" too.
Doesn't sound right. Even the stock F36 shafts are 1-3/8" At least on my buddy's 1981 model, they are. 1-1/2" are large.
gettaway
Post by gettaway »
Maybe the guy used a tape or ruler to measure and got it wrong, see if he can put a set of calipers on it and measure the shaft
1984 Silverton 37C
Silver Lining
Scott
gettaway
Post by gettaway »
sorry read your post wrong, I was thinking you were looking for a set of shafts not prop, if it is the props, the prop size should be stamped on the hub somewhere
1984 Silverton 37C
Silver Lining
Scott
rossjo
Post by rossjo »
1-1/4" STOCK 1974 F32 shafts here.
