10 meter mid cabin list to starboard
koviak
Post by koviak »
My 10 meter has a list to starboard I noticed while at the dock. Exhuast port bottom is at water level while the port side is clear by about 1 1/2". Noticed this last season and before I loaded gear on board it still favors that side. Not carrying any thing on that side as the tools and parts are on port side. Fuel tanks are balanced, Could it be just the design with the helm, galley and head on that side causing this. Even while running I need more tab down on this side. Had a guy that weighed 250+ stand on the port side and it leveled out. Thinking maybe adding some weight as ballast but unsure if I should.
Dennis
1989 10 Meter Mid-Cabin
jefflaw35
Post by jefflaw35 »
i dont know anything about that, but after all my balance research, I to am ready to add a couple boxes for weights if need be. Really tough to figure out on land, I know what Im adding in but if i get to heavy on one side or forward/backward, im sure I will have to make up for it. Just hate to ADD weight. im sure im wrong but its something I have been thinking about
that seems to be a lot of list.
My suggestion is to get a sailboat curved bubble guage to accurately measure the list port to stbd.
You cann easily calibrate it by setting a standard bubble level on the transom and then adding some weight to then have both at zero, then remove the standard bubble level.
Now you have a reference.
I would look further, surely these vessels did not all list when new....
Allen Sr
Post by Allen Sr »
My F36 lists to port. Has done it since I got the boat. I can't figure it out. :?
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
S.A.M.
Post by S.A.M. »
Dennis
My '90 MC sits exactly the same. I believe it's do to the head and galley being to starboard. Plus all the electrical and helm there too.
The port side is light with only a wet bar.
Sherman
'90 10m Midcabin
S.A.M. wrote:The port side is light with only a wet bar.
Not enough beer on that side to compensate :?:
Mike Kulp
Post by Mike Kulp »
Dennis mine lists also but only about a half inch, I have the wet bar with ice maker on the port side, two spare anchors with six feet of chain and 150' of line under right rear seat, all my dock lines under port side front seat and probably 300 to 400 pounds of tools, spare parts, cords in port closet in aft cabin and have my 8hp johnson mounted on port side of swim platform.
Mike 1986 10 Meter mid cabin
Ready probably has it right -- ADD BEER UNTIL LEVEL (or you don't care anymore :lol:)!
k9th
Post by k9th »
I like the beer for ballast idea too. Best way to keep everything on the level.
Landlocked
Post by Landlocked »
My 11 meter sedan lists like Koviak describes. I've always assumed it was because Trojan put the two A/C compressors, the wet bar, the lower helm station and 90% of the boat's wiring on the starboard side. All tankage is down the center so the only thing to counteract the stbd weight is the galley and head on the port.
Lake boaters skip the salt...
1985 11 Meter Sedan
1972 Newman Bassboat
1990 Cyclone Jetboat
koviak
Post by koviak »
Looks like we are in the same boat! (Had to say it). Don't really drink beer so if I can convince my wife it is for pure study I will take (2) 120lb girls on each outing and see if this helps. :D
Dennis
Mike Kulp
Post by Mike Kulp »
Now you are talking, let me know how that works out for you :lol:
rbcool
Post by rbcool »
My Tri will list to Stbd 1.5" when water tank (100 gal. port-aft) is empty. Only takes about 30 gal. to make her right.
And I'm NOT putting 30 gals. of Rum onboard!!! :lol: :lol:
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
BarryL
Post by BarryL »
My 10 meter Mid cabin is a 1990 and has no noticeable list at all but I did install some semi permanent seats in the cockpit and there are more of them on the port side but all of the seat material I installed weighs less than 75 lbs. I don't have a generator installed yet but when I do I am thinking in the lazerete aft of the motors. I have a Kohler 6.5 with sound shield all ready to drop in as long as it will squeak in without removing an engine. I can forward pictures of the boat at the dock if you want a frame of reference.
Barry
BarryL
Post by BarryL »
BTW I still have the bar/ice maker/fridge combo unit on the port side which is not lite.
Barry
