RWS, do you have any pictures of what these are like? If they help with fuel economy I'm all for it.RWS wrote:..........while she is still on the hard it might be a good time and easy too to add drop fins to your trim tabs.
Project: Trojan 10 Meter Express
I think he meant "floor step switch/valve"Natchamp wrote:John,jhalb wrote:Mark, I see you replaced the floor steep switch on your head. Do you still have the old one? I could use it if the repair on mine doesn't hold. If you want to sell it let me know.
What "floor steep switch" are you referring to?
go to google images ant type in thisNatchamp wrote:RWS, do you have any pictures of what these are like? If they help with fuel economy I'm all for it.RWS wrote:..........while she is still on the hard it might be a good time and easy too to add drop fins to your trim tabs.
bennett "drop fins"
numerous pix better than mine.
These are a diredt bolt in replacement.
Same attaching points
same width
but:
longer
PLUS
the drop fins
equals more lift.
Well,
I’m getting closer and getting the stainless steel top done is a major milestone. I still have to install some front struts for support but it’s pretty much complete and installed. I will start on the canvas work very soon. I also installed all my zincs but that isn't nearly as interesting to show as the top!
Crazy Yankee
RWS.....we have the same problem. I was told it was condensation from the air conditioner, but I'm almost positive when we put in a Mermaid last year we drained that into the forward bilge. I just pumped mine out for the second time this season yesterday.RWS wrote:good move on the crapper Mark.
just replace all the soft parts and you're good to go.
This was important durin my quest for efficiency in getting RWS up to .83 nmpg. ESPECIALLY if you have full tanks and a number of guests/gear.
Keep taking those photos and see about getting a magazine article done. If I were you, I would "shop" it.
While you are in the head I wonder if I can share a problem I have on mine with you that I have been unable to solve.
We seem to be collecting water inside the shower sump.
I can't tell if it's seawater, bilge water or rainwater.
I originally thought for a long time that it was bilgewater when the fuel tanks are empty, collecting at the fwd engine room and seeping into the shower sump beside the sump hose,, but I have since sealed that hose opening on both sides with RTV. I also put a plug in the thru bilge overflow hole.
Just something to consider while you are in your head, as the two are identical. Might help eliminate a similar problem with yours.
KEEP POSTING MORE PICTURES!
