getting the motors out of a aft cabin tricabin
kevin babineau
well ive got a guy with a boom truck but the boom isnt gonna fit in the window. im hoping to just bring the cable down through the window and muscling the motor back and through the window. any experience with this?
kevin babineau
Some disassemble the engine, remove heads, manifolds, intake, trans....etc.... and end up with just the block to remove.......maybe more work but might be easier and safer in the long run....................John
1998 Kawasaki ZXi 1100
kevin babineau
- 1995 390 express
kevin babineau
Rig it..
Build a frame from timbers and lift the motors out of the stringers, put the sole, or a temprary plywood floor down and roll the engies to the hatch or window on a good furniture dolly, this way, you get the motors in an easier position to pick from the cabin without worrying about trying to reach all the way into the boat with some sort of boom , fork etc.
I pulled the engines from my F32 with this method and a friend.
I built (2) 2X4 "A" frames that rested on the saloon sole at each end of the engine hatches, spanned the opening with a 4x6, added a couple of gussets and lifted the engines straight up with a chain hoist, I put the hatches back in place, I placed 2' x 8' pieces of 5/8" plywood over the haches, out the sliding rear door sill and over the cockpit floor, I lowered the engines onto a heavy duty furniture dolly, I then rolled the engines out the door into the cockpit and lifted them out of the boat with a hoist at the cub, took anout 45 minutes to get both engines out.
I had the engines ready prior to moving the boat to the hoist, so that expedited the process, but getting the manifolds and risers off, starter alternator, cooling system and raw water pump makes the engines much lighter and a lot smaller in deminsions
I'll post a few photos if your interested, but, I dont want to be accused of
"showing off" the 165's! LOL
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
kevin babineau
jefflaw35
jefflaw35
+1 on that!!! mine was scary!! its not a job for the light hearted and its all different for each model boat like Capt M says.... reguardless it stinks and takes some serious thinking!!captainmaniac wrote:No offense to those who have already posted, but I suggest you not do anything until you get some responses from the TriCab guys that have done this already. Every boat design is different, and a method that works for one design may not work for another.
jefflaw35
