1975 Trojan F30 AC/DC Panel 3 Position Switch 0,1,2, 3
Smokeleez
Post by Smokeleez »
Hello All,
Hope you've had a nice summer thus far.
Question on the AC/DC Breaker Panel. My 1975 F30 has this switch/round knob with 3 positions past 0: 0, 1, 2, 3.
Would you happen to know what these refer to and what each position means? There is an Inverter hooked up.
Thx kindly.
Vitaliy
Post by Vitaliy »
if you could posibly provide a picture it would be much easier to identify
on my f74, the standard sentry system has one knob, it has SHORE / GEN / OFF
shore being top midle, off being right and gen being left
so i gope this helped you out
1974 F36 Tri-Cabin "Jorallyn"
Welcome aboard. I'd say this is an after market switch that was installed perhaps to accommodate the inverter if it is integrated into the ships entire AC system. Marine AC source selector switches will be labeled to indicate the source such as "Shore", "Ship" or "Generator", "Inverter", "Shore 1/2" etc. Easy enough to tell which source each number represents by simply turning off inverter and genny, plug in shore power, and rotate the switch until an AC load turns on (lamp, microwave, or meter at panel, etc). Then label that selection. Disconnect shore power, turn on the genny and again rotate the switch until loads turn on again and label, and repeat. You may also have two AC inlets to consider for a 50 amp service sometimes managed by a rotary selector source switch or breakers. Typically a source selection switch for marine apps have an "Off" position in between two source selections, ie "SHORE - OFF - SHIP", this way a source is physically disconnected before connecting to the next source. Also check to see how many wires from each source are hooked up to the switch, should be at least a 2 pole switch so you can hook up the hot and neutral from each source. If it's not a marine unit, this may not be the case.
The one on My F36 is shore-off-gen. going left to right or clock wise . One knob switch
Photo would be great .
Possible battery switch - Off / Battery 1 / Battery 2 / Both
Smokeleez
1975 Trojan F30 Breaker Panel Swtich/Knob
Post by Smokeleez »
Thanks all for your posts - very helpful. I'll try your suggestions this weekend.
Here is a pic of the switch/knob.
http://s1174.photobucket.com/albums/r62 ... erator.jpg
Thanks.
