transmission to prop shaft disconnect question
Ok I have taken the 4 bolts that seem to connect prop shaft coupler to transmission flange or coupler off. The prop shaft is not coming loose from transmission. I also completely loosened stuffing box. Prop was removed for transport and I can not rotate prop shaft by hand. I am wanting the prop shaft disconnected so I can briefly put transmission in gear when I do my every couple weeks crankup on the engine while boat is blocked up out of water for renovation projects. One other thing I have checked and there is no set screw on prop shaft coupler. May be a key I have not found but no set screw. This is on a B/W velvet drive with Crusader 350. Transmission is straight or direct drive 1:1.
trying to insert picture[img][img]http://i1066.photobucket.com/albums/u42 ... f19c5a.jpg[/img][/img]
Try tightening the packing nut down just enough to give space between the coupler and the packing nut so there is room enough for the shaft to slide back. There is no key on the coupler itself, only on the prop shaft/coupler half and the output shaft of the tranny/coupler.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
- vabeach1234
It appears the shaft log hose is too long. I would think you'd want some shaft exposed just after the coupler. That way the shaft can slid aft and also you can ajust the packing nut and change the packing down the road.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Hampton, VA
vabeach1234 wrote:It appears the shaft log hose is too long. I would think you'd want some shaft exposed just after the coupler. That way the shaft can slid aft and also you can ajust the packing nut and change the packing down the road.
Looking at the photo I agree
The shaft log hose being too long, yep that is got to be it. I thought this configuration looked a little strange compared to some I saw pictures of. I have plenty of shaft log hose to work with. I will start by cutting a couple inches back. Just so I am clear, obviously there is no set screw on the prop shaft coupler to secure the coupler to shaft. But there will be something like a woodruff key on prop shaft to secure shaft to coupler???
Bob, are you refering to the key on the shaft to the coupler?
On my boat the Velvet drives and the Twin Disc's have a centering ring the couplings, one side is female the other is male, and it is a pretty close fit, so this may be what is temporarly holding these couplings together. the lip is about 1/8 or 1/16th of an inch.
also agree that the shaft log hose is much long
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
Most of the pressed on couplers have set screws as well my pics of couplers and removal.larryeddington wrote:My bet the centering ring, mine was pretty tight when took it apart, but you do need some room to slide shaft back.
http://www.trojanboatsforum.net/wforum/viewt ... ht=coupler
Am I the only one thinking the obvious? While it does seem your shaft/shaft log clearances could be improved... this seems like quite a project in order to excersize your gears on the hard.
It seems much simpler to put some good lubricant on the shaft/cutlass bearing and a little on the shaft/packing union for the short bits of dry running you will do. I think it's a great idea to run the equipment once in a while on the hard but the shaft spinning would be less worrisome to me than impellers and exhaust hose damage.... and even these would be fine with short bits of dry running.
Noticed the locking jam nut is not against the packing nut, baybe was maybe not, if not it should be to keep everything water tight.
I would be interested to see how whoever put that together got it all in there with so little slack.
Thanks again for the responses and advise. Been around boats all my life but this is the very first inboard engine I have owned. I am learning as I go and have learned a great deal from you guys. I am going to replace cutlass bearing and restuff packing box as part of my renovations. I unscrewed the jam nut from packing nut to just see if that would loosen things a bit. I also thought how in the world was this ever put in with the seemingly non existence slack in the system.
