Winterizing A/C
Winterizing A/C
Hello everyone, have been reading many many posts on here lots of great info. Having my boat pulled out monday just working on getting some of the systems winterized before hand. I have done the generator and freshwater system. Was hoping to tackle the A/C unit today but I not sure of the procedure. I see were the seacocks are and was thinking to just shut it off disconnect the hose hook some antifreeze up and turn on the a/c, but it is not like there is a exhaust so How do I circulate it it through.
A few other questions 1) When I turn the key to start one of the engines a Buzzer goes off ????
2) I dont believe the previous owner did a final waste water pump out will this be a problem over winter ? If so what are my options
Thanks in advance everyone.
1978 Trojan F36 Tri Cabin
- The Dog House
The buzzer is most likely a low oil pressure warning. It should shut off once the engine is running. The waste water will be an issue. Can you get it pumped out before the boat is pulled? That's probably the easiest thing to do.
Holding tank gonna be a problem unless you keep the compartment heated where the tank is.
As for the ac find the water discharge ports outside and run the antifreeze thru til it comes out pink or whatever color your using. You may have to have someone watch for you and yell down when its ok to turn off. The buzzer......low oil pressure.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
On the A/C, the seacock needs to be closed while the boat is still in the water, otherwise it's nearly impossible to prime the pump. If was closed before it was hauled, then you can take the cap off the seacock and pour the pink into the strainer and it will pump all the way through and out the hull.
If that's not an option, disconnect the hose on both ends of the pump and pour pink through until it comes out the other side. Fill the seacock with it too. On the holding tank, pour a couple of gallons down into your deck pump out, that's really all you can do along with flushing the head after pouring some in the bowl.
marklo154 wrote:ok. The other engine buzzer doesn`t go off on start up so it might be the buzzer itself . Each one does show a light which stays on.
What is the oil pressure Gage reading when running ? ?
I'd be worried about the holding tank. I don't know how much fluid you have in there but even if I did, I would never venture to guess how much antifreeze would be enough to keep it from bursting given that the water in the tank will dilute and reduce its protection rating....how will you know how much is enough unless you test? If you can't pump it out before you get hauled (other marina close by?), try and find a mobile pump out.
- Commissionpoint
Maybe fill the tank the rest of the way with some -50 antifreeze and just hope for the best if you absolutely cannot get it pumped out.
You could always sell poo poo sno-cones if it doesn't work out.
