PLEASE HELP - Metal Shavings Rust Stain Removal
I was recently doing a project that resulted in drilling some metal on the deck.
Numerous tiny metal shavings were missed in the cleanup and are now on the fiberglass fwd deck and the painted concrete dock.
Other than soft scrub does anyone have any ideas for an acid type product that will not harm the fiberglass?
Photo follows below.
THANK YOU !
Lemon juice and salt . I have taken a slice of lemon and salt and rubbed it on the stain . You can also make a paste and let it sit .
http://www.getridofthings.com/stains/ge ... stains.htm
Try FSR (Fiberglass Stain Remover) just do a search... Good stuff.
BarryL
Rust removal magic in a bottle
Post by BarryL »
RWS,
if you have a water conditioning supplier (Water softeners etc..) get some rust prohibiter that is normally added to the water softener salt.
Use it as a paste with a scrub brush and the rust will disappear forever.
Up in my neck of the woods the trade name is "Iron Out" and is available at Menards, Home Depot, and Lowes home improvement stores. It wont harm the fiberglass but will give off a pretty good stench while in use so use it carefully.
I have used it and it works like a charm.
Good Luck,
Barry
Stripermann2 wrote:Try FSR (Fiberglass Stain Remover) just do a search... Good stuff.
X2 I have used that also
cmcmjk
Post by cmcmjk »
Bar Keepers Friend cleanser. Available at most grocery stores and cheap.
http://barkeepersfriend.com/using-bar-keepers-friend
I had a rubber backed commercial rug that came back from a rental service that had steel shavings in it. I pulled it up after a weekend of fishing and swimming and was horrified when I saw all the rust stains.
GET THE POWDER NOT THE LIQUID!!!
Wet the surface and sprinkle it on to make a paste, rub it in and let it sit.
If this doesn't work try the RUST OUT from the water treatment place. It's more expensive but has worked for me.
PS: Three more ideas!
Muriatic acid on the corner of a rag - use gloves and don't breathe the vapor or get it on anything but the fiberglass. rinse well when done.
Heavy duty toilet bowl cleaner will work sometimes. I think the one i used was called Sno Bowl, just make sure it has acid in it.
There is a product called Mary Kate On & Off that most marine stores sell, it comes in a liquid or gel and is supposed to be good stuff (I've never used this one).
Mike & Cynthia
1990 10 Meter Mid-Cabin
Traverse City, MI
Commissionpoint
Post by Commissionpoint »
Slimy Grimy.
http://www.slimygrimy.com/
CLR
http://www.thecarycompany.com/container ... Ogodh3AAuQ
Slimy Grimy should be stocked in most marine suppliers, CLR can be found in most box stores.
classicf25
Post by classicf25 »
ON and Off is amazing for stain removal on fiberglass! Just don't let it drip on trailers, etc.
1973 F25 TROJAN
1973 F30 SPORTFISH
1979 SKIMMAR 7'
Lawrence
Clr, buff magic....
guglielmo6160
Post by guglielmo6160 »
west marine sells "Rust Stain Remover", it works perfectly, I used it all around my dock and boat, let it sit a few minutes, then use a scotch brite pad and its gone,
I havent seen anything else work better, I have a habit of leaving razor blades all over the place and if you've ever done that you know that over night it leaves a nice rust outline of the blade,
this stuff takes it right off
1983 10 meter express
Larrys78
Post by Larrys78 »
X2 FSR
1978 F-32 Knotty Playsure twin 350xl 270 Crusaders
EDMONDS WA
Teach a boy to fish and he will go hungry supporting his boat
http://s1123.photobucket.com/albums/l550/Larrys78/
larrys@wsconline.net
DOUBLE R
Re: PLEASE HELP - Metal Shavings Rust Stain Removal
Post by DOUBLE R »
testing only
MY CURENT FLEET
2003 KEY WEST 2020 WA
1978 ASHCRAFT 14' SKIFF
